Old 05-27-2004, 11:37 PM
Sheresh07 Sheresh07 is offline
Blow off valve does........?
What exactly does a blow off valve do on an engine?
I was thinking it might have been some sort of contraption to release compression pressure so your engine didnt explode at lets say 8.5k rpms, but my pops seems to disagree and doesnt know what its for either.
Old 05-28-2004, 12:08 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Blow off valve does........?
a blow off valve relieves pressure in the charge pipes of a turbo kit. When you let off the gas, the butterfly on your throttle body closes and all the air that was going to your engine reverses it's path and heads for the turbo again. This isn't good, so people use a blow off valve.
Empty Pockets Racing Member #1
Old 05-28-2004, 03:28 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
couldnt had said it any better my self but ill try ............. jk
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 05-28-2004, 06:46 AM
Ah k, thanks, is it true that a turbo also uses an actual fluid and thats what a waste gate is for?
Old 05-28-2004, 09:41 AM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
a wastegate is used alot for smaller turbos to reduce lag and preventing them from spinning to fast at high rpm's
A wastegate is a valve that allows the exhaust to bybass the turbine blades within the turbo. The wastegate feels the boost pressure and if it gets to high i could be a sign that the turbine is going to quickly so the wastegate bypasses a portion of the exhaust around the blades so that they can slow down.
Old 05-28-2004, 09:42 AM
Banned
so no its not for a liquid its for exhaust gas.
