Old 05-27-2004, 11:03 PM
SpasticMonkey85 SpasticMonkey85 is offline
Expert Tuners, I need your help
I just installed a Zex stage 1 camshaft on my 96 GS-R that has the other following mods.
AEM Cold Air Intake
DC Sports 4-2-1 Exhaust Header
ApexI N1 Cat Back Exhaust
Skunk2 Performance Intake Manifold
JG Bored Throttle Body
MSD Ignition Wires
ACT Heavy Duty Clutch
Short Shifter
Hyper Ground Wires
Platinum +4 Plugs
I am going to pick up a VAFC to see if i can get some more power out of the new cam. I don't really know that much about tuning but i had a couple questions.
1. Can i just test n tune till i get it right or could that cause damage?
2. Is there any archives of vehical specific tuning information on the web?
3. Do you guys know a good Vtec engagment point for this particular cam?
Old 05-28-2004, 12:20 PM
Re: Expert Tuners, I need your help
come on guys i know someone can answer these questions.
Old 05-28-2004, 01:46 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
To truly tune your engine, you should get on a dyno. There's no real way to tell what kind of gains your settings are giving, or which ones are better, you if you don't.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 05-28-2004, 04:22 PM
I have no dyno access, i was planning on using my ASS Dyno.
Old 05-30-2004, 07:15 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
If you don't have a dyno or access, the next best thing would be to order a stand alone wideband o2 sensor like www.plxdevices.com and at least tune your motor to stoich conditions. Running a little rich can produce more Hp, but you'd have to dyno test to be certian.
Old 05-31-2004, 05:45 PM
YellowITR479 YellowITR479 is offline
Oh boy...here we go....tuning while driving...either do what jcrx said....$400.00 will save you thousands
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 05-31-2004, 08:12 PM
Thanks for the advice but no one answered any of the question given.
Old 06-01-2004, 01:09 AM
Re: Re: Expert Tuners, I need your help
1. NO
2. NO
3. NO
Happy now?
