Old 05-27-2004, 09:18 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
singlecam/doublecam theory
Ive been thinking about this for quite a while...anyways
Ok, so lets take two engines...same block, internals, compression ratio, all the little details the same on the bottom end. Same for the intake mani, injectors and all that stuff. One has a single cam cam head and one has a double cam head. Same lift cam/cams on both engines, same port sizes/shapes, same fuel maps, same everything cept one has one cam and one has two. Both set to 0 degrees adv/ret. Will one engine make more power than the other?
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 05-27-2004, 11:25 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: singlecam/doublecam theory
Hard to say I'd think DOHC, except maybe between a jdm d15b vtec vs. a DOHC ZC; in that case it'd be too damn close.
Old 05-28-2004, 12:25 AM
b16a3sol b16a3sol is offline
if everything is exactly the same, except for the number of camshafts, then i would have to say the SOHC, simply because the motor has to rotate that much less mass. there is one less camshaft, pulley, many springs, valves, resistance from friction for all the parts, etc. the whole point of adding another camshaft, is to allow the entire head and manifolds to be restructured to allow more air into and out of the cylinders. if thats not taken advantage of by changing just about everything, then adding more parts is not really beneficial.
thats my take on it anyways, could be wrong...
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-30-2004, 07:30 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: singlecam/doublecam theory
Right o, the point is to effect airflow both in and out in relation to each other.
Old 05-30-2004, 08:51 AM
seniorbigs seniorbigs is offline
I think the main advantage of DOHC is valve placement in the head, which will dictate combustion chamber shape to some degree. Cam followers can be made smaller and lighter with the valve stem closer to the cam lobes.
Old 05-30-2004, 11:47 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
fact is, parasitic drag would make the DOHC slower.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 05-31-2004, 03:31 AM
maybe if everyhing else was exactly the same you'd lose 1 hp, but FACT is DOHC are faster. Reason being that the intake and exhaust cams are set to maximize flow, and that is the whole point of have two cams. The weakest DOHC is the first ZC at 124hp and it was quite a few Hp faster than it's peers.
Old 05-31-2004, 10:52 AM
PunkAlex's Avatar
ok then, real world application. Say we were to take a d16z6, give it the beefed up internals similar to that of a b16, cam w/ same profile, same fuel map, same revs (however the hell you would be able to do that ), same compression etc. would it make the same power as a b16?
Old 05-31-2004, 01:41 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
on vtec sohc there is no agressive lobe for the exhaust(not enough space).i think they would make the same power.
Old 05-31-2004, 11:22 PM
Re: Re: Re: singlecam/doublecam theory
if everything was perfectly equal between the SOHC and DOHC? i would think that, while minor, the drag created by the extra rotating assembly would cause the engine to be just a hair less powerful. in real world applications, you are absolutely correct, but what he said was everything is identical except the number of cams..
84 Civic 1500S
Old 06-01-2004, 01:25 AM
In that case, what if there was no gravity and we could all fly? It's retarded, you're trying to turn an apple into an orange. Or what if, what if, what if, we made the second cam out of superduper light titanium alloy composite fibers, and it could just be there, and not weight anything, what if, what if, what if...
Point is, there's no use trying to compare the effieciency of two different motors in a vacuum.
He asked with all things the same, which is faster, and that's going to be the DOHC because you can tune the intake exhaust for better effiecency. Since you can't tune a SOHC this way, you can't say all things equal, or exclude this as a factor.
Old 06-01-2004, 11:13 AM
PunkAlex's Avatar
Yeah i know ability of tune will always be a plus for DOHC....and in the real world a b16 will always make more power mod for mod than a d16. I wsa just wondering if there were any more advantages to DOHC over SOHC besides plug placement and tuning
Old 06-02-2004, 02:34 PM
jcrx, i wasnt arguing with you, you are right, a dohc is more efficient, period. i was mistaken at first and trying to figure it out, thats all
84 Civic 1500S
