Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-27-2004, 08:01 PM
udelblue udelblue is offline
squeaky springs?
I have intentions of replacing my stock suspension springs and shocks with aftermarket probably koni's yet now i dont have the money(always a factor). til i get the money is it ok to drive around on springs that squeak? is there any safety issues i should be concerned about? any advice?
Old 05-27-2004, 11:20 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Re: squeaky springs?
It's probably the bushings that are squeaking. After I lowered my car the sound became very pronounced.
Old 05-29-2004, 02:19 PM
BullShifter's Avatar
I agree, most of the time is a bad bushings, ball joint, or tie rod. If the springs is the cause then it is likely to have a broken coil.
Old 05-30-2004, 12:16 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
my car squeaks too. i thought it was the struts on my car because i was run n stock struts on neuspeed race springs. so i replaced the struts with bilstein struts but it still squeaks a little bit, but not too much. Bad bushings wont cause too much problems right? do i need to replace them?
www.MEDIUMRACING.com
Old 05-30-2004, 03:15 AM
Bad bushings can cause vibration & noise, should be replaced. If it's a ball joint or tie rod that should be replaced ASAP.
