Old 05-27-2004, 07:59 PM
Bob Kivoski Bob Kivoski is offline
Question Replacing Ignition Lock Cylinder
93 Dodge Carivan 2wd,auto,3.0L
Has anyone replaced Ignition Switch Lock Cylinder in this model?
I do not have to pull steering wheel, just plastic housing on column. I suspect I will need to remove complete switch/switch cylinder and will learn as I go, but if anyone has done it.....
Thanks,
Bob
Old 07-09-2004, 10:40 AM
yangj99 yangj99 is offline
Re: Replacing Ignition Lock Cylinder
Thanks,
Bob
You do not need to pull steering wheel. You need a T20 star wrench with A HOLE IN THE MIDDLE to take 3 screw off the ingition switch module, unplug two connector and insert your key and turn to get the cylinder out. You can only get the cylinder from dealer and it will cost about $100 for the cylinder and about $50 to have the locksmith to key the new cylinder to your old key. GOOD LUCK
Old 07-09-2004, 12:07 PM
slantsixness's Avatar
slantsixness slantsixness is offline
You can get a replacement cylinder at any NAPA store, or most locksmiths. and it's not $100.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
