Old 05-27-2004, 07:04 PM
joemathews's Avatar
joemathews joemathews is offline
MAP Problems Turbo Teg
So my buddy Brian with the turbo integra is havin some trouble. His problems are as follows:
1) His car upon starting would rev to 2000rpm then stall
2) He removed the MAP (still connected by wires to the harness and the throttle body, but not plugged in), and the car ran smoothly wihtout stalling
3) He connected a friend's MAP (from a civic si, not a gsr), and the car ran, but not entirely smoothly (it ran more smoothly reading ambient air).
4) He thinks it is the fuel pump, because he says it is making a weird noise
5) He also has oil bubbling out of the silly little breather valve that sticks out of the valve cover of integras.
Anyone have any advice on these symptoms?
1996 Eagle Talon
Old 05-27-2004, 08:00 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: MAP Problems Turbo Teg
How many psi is he runnning? Is he using fuel management? Does he have any work done to the motor? Is it an LS or GS-R?
Old 05-27-2004, 08:10 PM
joemathews's Avatar
Sorry for the ambiguity...he's running 4 psi, no fuel management, no work done on the motor, and it is a B20 with a gsr head.
1996 Eagle Talon
Old 05-28-2004, 01:33 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
he shouldnt be runnin any kind of boost without some kind of engine management, it is probably runnin really lean on boost since there no kind of fuel management adding fuel on boost
Team Lonely Drivers
Old 05-28-2004, 04:38 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
he needs to look into injectors at least !!!!
Old 05-28-2004, 04:53 PM
i think he is kind of stupid to run boost with no engien management. tell him to get soem kind of engine management, who knows what kind of damage he has done to his motor already
Team Lonely Drivers
Old 07-01-2004, 02:26 AM
RPMtuner RPMtuner is offline
i think he needs somthing colled a map bypass ther sell them on over boost.com
