Old 05-27-2004, 06:06 PM
tomt tomt is offline
1998 cavalier vent fan speed control
My interior vent fan speed control only works on 3rd and 4th position. Won't work on lower 2 speeds! Help! What could be wrong?? Fuse..switch?? Costly repair??
thanks
Old 05-27-2004, 06:48 PM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
Re: 1998 cavalier vent fan speed control
inside the switch they're are wire resistors to determine how much voltage to give the fan to control how fast it spins. they should be inside the switch.
Old 05-29-2004, 08:15 PM
GTP Dad GTP Dad is offline
Pontiac Guy
If the Calalier is the same as most other GM Products you will need an new fan resistor. They are available at the GM Dealer for about $20. Find the fan in your car and the resistor should be located very close to it. Once you replace the resistor the fan will run on all speeds. If you have a mechanic do it should take about half an hour to replace.
Old 05-30-2004, 01:58 PM
Re: Re: 1998 cavalier vent fan speed control
Thanks for the response. What does the resistor look like. Color size, shape when I find it??
Old 05-30-2004, 03:32 PM
Pontiac Guy
It has a quick connect plug on the end and is rectangular on the bottom. Will have a foam seal around it. Usually the wires coming out of the bottom are red and black it is held in by two screws.
Old 05-30-2004, 11:38 PM
thanks
