Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 05-27-2004, 05:36 PM
lilLB179 lilLB179 is offline
how to romove 97 civic door handle?
I'm running into problems removing my passenger side door handle. I have the interior door panel removed and can get to the handle but after removing some parts I still can't get the thing to budge. Any help?
Old 05-29-2004, 02:39 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
Re: how to romove 97 civic door handle?
try tapping with a hammer on the inside. if you were able to get the driver side off, and you removed all the same stuff from the passenger side, it may just be stuck a bit
Old 06-01-2004, 10:29 PM
maxwell maxwell is offline
Is the door handle still attached to the door panel?
Old 06-01-2004, 11:47 PM
lkailburn's Avatar
^^ haha thats a good thing to check.
make sure you did the following:
-Remove door panel
-Remove lock/key assembly... there is a pin on the bottom section(like the pin on the door handle portion)
-Take off the 2 bolts on the handle
-Zip tie or remove the "lock cable"
-Pull out the handle
-Unscrew the "opener cable"
Old 06-06-2004, 10:13 AM
96Civic_Coupe 96Civic_Coupe is offline
Banned
are there any websites for this ? that show you how to remove the exterior door handles ?
