Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 05-27-2004, 12:28 PM
TiburonDelAsesino's Avatar
TiburonDelAsesino TiburonDelAsesino is offline
Lightbulb S/C VS. N/A Overview !!!
Heres a little research I have done to help those wanting to modify their 2.7L tiburon GT.
SUPERCHARGED 2.7L Tiburon GT
stg II S/C nxt gen 100hp $4920.00
CAI AEM 10hp $ 200.00
cat-back Mussa 15hp $ 800.00
Oil cooler Hayden --hp $ 150.00
stg II clutch centerforce --hp $ 400.00
9lb flywheel nxt gen --hp $ 400.00
engine mounts nxt gen --hp $ 315.00
Total Modifications - - - 125hp $7185.00
Naturally Aspirated 2.7L Tiburon GT
Total Modifications - - - 92hp $5145.00
stg III intake nxt gen 15hp $ 595.00
lower crank pully nxt gen 05hp $ 250.00
headers KRD 15hp $ 350.00
cai AEM 10hp $ 200.00
cam gears nxt gen 15hp $ 260.00
fuel tuner nxt gen 12hp $ 400.00
camshaft nxt gen 05hp $ 900.00
oil cooler Hayden --hp $ 150.00
G11 intake spacer nxt gen --hp $ 125.00
2003 Tiburon GT
Haydin Oil Cooler, Hotshots Racing Header, Injen SRI, Borla Exhaust, SR BBTB, NGM Stage 4 Upper/Lower Intake Manifolds, UD pullies, Apexi Grounding kit, ARK Front Strut Brace, Nology Coolwires, kspec motor mounts, greddy oil catch can, Tein pro suspension, Tein front/rear sway bars, SAFC Neo, 15mm Hub Adaptors, Invader CF hood, centerforce stage2 Clutch, Cumstom reground cams.
Old 05-27-2004, 01:31 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: S/C VS. N/A Overview !!!
next gen can give you car more hp than youll know what to do with
if you have the money thats the man to see
Old 05-30-2004, 04:01 PM
tibby01 tibby01 is offline
has he even sold anything yet?
Old 05-30-2004, 04:46 PM
Tib Guy
hes been selling alot!
hes the only guy/ co. that has been putting really good n/a numbers down
his s/c uprades are rediculous and he has somuch more planned to do
Old 05-30-2004, 11:42 PM
Exhaust O2 sensors N/a
I understand that most of the aftermarket exhausts for the 2.7 are not true dual exhausts. They connect before the cat with a Y pipe, and then split up again for the mufflers. If you wanted 2 seperate cats and exhausts going back instead of 2 Y connects how would you compensate for the second cat and muffler as far as the O2 sensor is concerned. I believe this setup would be best for the N/a guys but im not sure how to get correct readings with only 1 O2 sensor. If anyone can help out thanks.
2003 Tiburon GT
