Old 01-19-2002, 05:07 PM
b16a3sol b16a3sol is offline
keeping the amps cool
in my del sol, if i end up driving around all day with the stereo up, my amps start to overheat by the end of the day. if i have the roof back there and listen to it loud for a much shorter time they overheat as well. i know this is bad, and it is only a matter of time until it does permanent damage, so my question is how do i keep them cool back there? is it as simple as just putting a fan in there somewhere to get the air moving, or do i need to do something more drastic? thanks for any suggestions.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 01-19-2002, 05:24 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Re: keeping the amps cool
What amps do you have, how are they mounted, need more details. But yes, the solution would be some little fans... theres not much more then that you will be able to do.
AF's Official Asshole
RIP AUNIE
Old 01-21-2002, 05:18 PM
99AccordCoupe 99AccordCoupe is offline
You might also want to turn down the gain on your amp. I know you really don't want to that, but it'll defenitely run cooler.
Old 01-22-2002, 01:56 PM
Whtehnda93DXSdn Whtehnda93DXSdn is offline
Send a message via AIM to Whtehnda93DXSdn
Gains can be a factor as mentioned..depending on where and how your amps are installed you should be able to put fans where they are to help cool them..
Put 1 fan pulling air into where the amps are and one blowing air out so it will circulate it and keep the amps cool..
Not sure if this will help but I thought I would mention it....:frog:
another good honda site:
www.civicland.com
Old 01-23-2002, 12:24 AM
i made a box that stretches across the back of my trunk in my del sol. it is shaped like a right triangle when looking at it from the side. the sub is in the middle, and the two amps are on the either of the sub, with the heat sinks facing up as they should be. one amp is a 4 channel pioneer for the inside, the other is a bridged jbl to the sub. i understand that the amps cant make heat if they dont have electricity running through them which is done by turning down the gains which are at about 2/3 right now. the only problem with turning the gain down is that the deck has to go up which still creates distortion, defeating the purpose of paying a lot of money for an amp. any ideas on where the fans should be mounted, or how to wire them? thanks for the help.
Old 01-23-2002, 12:56 AM
sparq's Avatar
AF Premium User
Something you have failed to mention... which head unit do you have? And a solution to "needing to turn the headunit up" would be an RCA line driver before the amps, this increases the RCA's voltage, cleaner more powerfull signal, thus less of a need to crank the gains...
RIP AUNIE
Old 01-24-2002, 10:22 PM
Your headunit should throw out at least 4 volts to your amps. Otherwise a good line driver is will work wonders in your setup.
