Old 05-27-2004, 08:51 AM
vlady2k00 vlady2k00 is offline
Send a message via AIM to vlady2k00 Send a message via Yahoo to vlady2k00
Unhappy 1998 Grand prix GTP major front end noise...HELP PLEASE!!
my 98 GTP is making major poping and clunking noises when i turn left or right and it comes from both sides, this noise is been bothering me for a while. I changed the cv joints and the front struts because they were bad but that didn't do any thing. the mechanic had no clue where the noise is coming from. Please if anyone knows about this being a problem with other GP's let me know . another mechanic told me its the wheel bearings but i want to make sure before i drop all that money on it.
thanks
Old 05-27-2004, 12:07 PM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
Re: 1998 Grand prix GTP major front end noise...HELP PLEASE!!
Maybe the rack and pinion...I believe the recall was also on the '98 models. If yours hasn't had the rack and pinion fixed because of the recall, that could be it, or it could be the wheel bearings. I just had to replace one of those on my car. $595 for parts and labor.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
Old 05-27-2004, 12:48 PM
I thought the wheel bearing makes more like a humming or howling noise and not a poping cracking metal kinda noice cuz thats what i'm hearing thanks for replying and nice pics by the way....i'm posting some up soon
Old 05-28-2004, 04:31 AM
GTPgirl's Avatar
Yeah, my wheel bearing was a metallic whirring noise. But on my '97, my steering used to pop like something was hitting something else when I was turning...it only did it to the right, then I had the rack & pinion replaced, and it stopped.
GTPgirl
Old 05-28-2004, 09:00 AM
BIG-L's Avatar
BIG-L BIG-L is offline
I agree with GTPgirl,id go to your local Pontiac dealer and see if you Vin is included in the recall for the rack.......~Larry~
ClubGP Member 6530
Since 2001
Old 05-31-2004, 12:05 AM
R-ROD R-ROD is offline
I have a '99 GT and it had some clunking noises in the front end too. I could really hear it when turning left or right at slow speeds such as in a parking lot. Anyways, I took it to the dealer and they managed to fix it after I rode around with a tech in the passenger seat. I believe my service write-up said something about re-torquing the the bolts on the front subframe. Either way, something large was loose and not torqued down properly. Hope this helps though it sounds kinda vague. If I can find the service write-up I'll post their findings.
Old 05-31-2004, 07:49 PM
GTPgirl's Avatar
You don't have to go to a dealership to find out if it's included, you should be able to find the recall information at http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
GTPgirl
Old 05-31-2004, 08:28 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
My brother once on his nissan had the same problem coming from the shop. It was that the rack was loose, the mechanic loosen it a little to tight something else and forgot to tight it back. And my dad 98 Lumina was on the recall and the only problem he had was sometimes when turning to the left the steering wheel stucked, no noise, no nothing. Do you have similar problems?
