Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 05-27-2004, 01:29 AM
fiero_2004 fiero_2004 is offline
Send a message via AIM to fiero_2004 Send a message via MSN to fiero_2004 Send a message via Yahoo to fiero_2004
quad 4
hello i was gonna get a quad 4 to put in a 84 2m4. i was wondering if it would mount to the trany and to the car it self? any answers would be helpfull. if not what 4 cyl would mout to boath the trans and the car. i want to up grade from the iron duke. get more power the the after market 120 hp. thanks
Old 05-27-2004, 01:38 AM
coop8267's Avatar
coop8267 coop8267 is offline
Re: quad 4
hell just get the 2.8. you will have to change ecm and wiring harness anyways if you get a different 4 cyl. and you know it will bolt to the tranny. plus you got love the intake plenium!!!!
Old 05-28-2004, 12:55 AM
if i go with the 2.8. i would want to know the specs so i can compare. i plan on turning it into a drag racer so i want to get the best 4 cyl for it. is there a site i can go to to see the specs of that engine? thanks
Old 05-28-2004, 08:18 AM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: quad 4
Belive it or not, the iron duke is very popular in 4 cylinder class racing. It's been said a stock automotive 2.5L Iron Duke can run 180HP with minor modifications but because it was designed as an economical, low performance engine it is kind of limited. The S10 truck block is slightly stonger but would still need better insides to put out much more. The marine version (much coveted among racers) of the iron duke as well as the super duty 4 racing version (not very cost effective, the price tag on the bare block alone pushes $2K) can be built to put out upwards of 200HP.
If you need much more then that, I would also suggest moving up to the 60 degree V6 family (2.8/3.1/3.4OHV) as they will bolt right in to a 2M4 with little modification - basically swap the heavier struts in, change the ECM and harness and you're done.
I would advise against a Quad 4 - the tiny, poorly designed water pump(from a performance view) will never handle the burden of a Fiero's unique front to rear cooling system.
Check out Http://www.60degreev6.com for the 2.8L specs you wanted.
This site has some interesting info on the Iron Duke : http://www.k12.nf.ca/gc/Staff/Teache...ro/dukefaq.htm
You can find lots more with just a simple google search.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 06-04-2004, 04:17 PM
coop8267's Avatar
Re: quad 4
the super duty 4 is the best. the real indy pace car had one and i think they were pushing 270hp. the production sd-4's had 180 i think
Old 06-11-2004, 10:29 AM
Re: Re: quad 4
do u know where i can get one for cheap all i want is the block, crank and, cam ? i dont kneed anything else. thanks
fiero_2004
Old 06-14-2004, 10:42 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: quad 4
Well You could throw a 2.3 Quad 4 High output in it, that makes stock 180 hp with miner mods be up to 200
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 07-25-2004, 05:31 PM
eric block eric block is offline
Re: Re: Re: quad 4
fiero_2004
got alot of parts u now how to biuld a good one
