Old 05-26-2004, 10:22 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
New electrical problem...
Ok..so today after I install some new valve covers , msd wires , battery , msd blaster coil , new distributor cap and rotor..I go to hook my positive cable back up and my lights start bugging out. acting as if the hazards are on..so I try to start it and see if that stops it..maybe a ECU security thing ? Nope , no go. I suspect I left the battery disconnected for about 5 minutes while hooking the wires up.
My car has a security system in it but that hasn't worked for like 5 years ( says the gentlemen I bought it from. )
I can't drive it with my lights flashing and door buzzer going off when the lights flash. What do I do ? is there a easy way around this ?
Old 05-26-2004, 10:50 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: New electrical problem...
its the aftermarket wiring system, im 90% sure. welcome to the world of aftermarket fuck ups unfortunately there is no way i can offer to help on this one online, someone with automotive electronics repair experience and knowledge of this wiring system will have to go in and figure out what got fucked up. i guess somehow by moving stuff around and rewiring a few things, you reactivated the aftermarket equipment, and thats whats causing the problem. i cant think of any stock system that would do that, or any wiring problem that would do what you describe.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-27-2004, 12:48 AM
92rs25th's Avatar
Crap..-_- just another thing I need to spend money on. I can see it now..
Old 05-27-2004, 12:52 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
I would find the computer to the alarm, unhook it, and unhook everything its connected to, pull out the entire alarm harness... Make sure you cover up any exposed factory wiring.. (I use solder and heatshrink or liquid electrical tape)
1991 Camaro Z28
Old 05-27-2004, 01:55 AM
Clevj001 Clevj001 is offline
hey i am in the autosound business and i have done alarms before and i my self have had this problem i can get you the sheets you need to locate whats what so you can get out of this mess just drop me an email at [email protected] and i will email the sheets and what to cut and stuff
ok?
later
justin
Old 05-27-2004, 02:28 PM
92rs25th's Avatar
I took my dash pad off ( under ) and just removed the Hornet controll box for the alarm and everything was good to go. No problems yet.
Old 05-27-2004, 05:16 PM
DaMoNe6969's Avatar
Glad to hear that worked .. You should still trace all the wires from the hornet harness and remove them! IMO
1991 Camaro Z28
Old 05-27-2004, 06:00 PM
89IROC&RS's Avatar
glad to hear it was an easy fix thus far. but i agree, if your gonna take it out, might as well take out the wiring, for cleanliness, appearance, safty, and the future headaches it might produce.
Old 05-27-2004, 07:12 PM
92rs25th's Avatar
Aye..Tis a long process though and thus far , As I have moved , I have no garage for this and if I do it in the parking lot of the apartments we live in , they will through a tissy fit if they see me working on my car in the lot and have it towed ( yeah right..I'd bust some caps in their crowns first. ) BUt I am also moving in two months so when I get into our new house and a garage , I will definently remove all the crap wiring in that car. Man..There is like a 100 wires O.o hella wires..I think it's an OLD old car alarm system.. But yeah , I figured if I am not using the alarm , Might as well pull all the junk wires off my main harnesses and re-hardwire the lines back together , Less electrical problems in the future I suspect.
Much appreciated on your guys help and opinions
Great forum by the way =D
Old 05-27-2004, 09:45 PM
DaMoNe6969's Avatar
Glad we could be of service
1991 Camaro Z28
Old 05-27-2004, 10:33 PM
89IROC&RS's Avatar
i do like it here
