Old 05-26-2004, 11:16 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Pistons...
Does anyone know what kinds of gains I could expect from a set of CTR pistons in my basically stock (i/h) B16A?
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 05-27-2004, 12:27 AM
SenseiAccord SenseiAccord is offline
Re: Pistons...
sorry i dont get it... u are gonna put CTR pistons in ur b16a? isnt a b16a a CTR motor? try rephrase and ill help answer if i kno.
Old 05-27-2004, 01:17 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i wouldnt expect more then 5whp, you might get more with other parts because all the other parts compliment each other like bigger cams and more hiflow intake mani.
Team Lonely Drivers
Old 05-27-2004, 01:19 AM
b16a3sol b16a3sol is offline
Re: Pistons...
i thought ctr pistons raised the c/r pretty drastically. should result in a little more than 5, but i could be entirely wrong.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-27-2004, 01:24 AM
i mean the type r motor only has about 25 more whp then a b16, so you figure with the cams, intake mani, port polish, pistons, exhaust all of which are better then a regular b16, how much would you expect from an upgrade like that ?
plus liek i said, all of the parts compliment each other, like with jsut the pistons you might get only 5whp, but say if you had cams and the intake mani already on then add the pistons, you might see 8whp. all the parts compliment each other, get waht im saying ?
Team Lonely Drivers
Old 05-27-2004, 01:29 AM
B1SiR6A's Avatar
Re: Pistons...
Yeah I was kinda hoping the compression would help me get a bit more than 5 horses. Sensei the B16B is the CTR motor (Ricochet has one) I have the B16A which is the JdM Civic SiR-2 motor... Ricochets motor is basically mine on steroids...
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 05-27-2004, 01:37 AM
but of course i have never done this nor have a seen a dyno of this being done so maybe im completely wrong, it could be like 10whp, but its not more then 20whp
Team Lonely Drivers
Old 05-27-2004, 02:00 AM
i was reading a post somewhere and it said taht putting in CTR pistons in a b16 will only yield a 10.8 from a stock 10.2. if thats right, then that aint much.
if thats true it might be better to just buy aftermarket pistons with higher comrpession ratios
Team Lonely Drivers
Old 05-27-2004, 04:16 AM
Re: Pistons...
yea actually getting aftermarket pistons might be the way to go that way u can seriously bump it up to like 12:1 or something. Since u are ripping apart the engine anyway... might as well put something worth the hassle that will give u solid gains.
Old 05-27-2004, 07:26 AM
B1SiR6A's Avatar
Re: Pistons...
But they cost so much (aftermarket)...I was eyeing those ctr pistons on inlinefour for $200 and thought it was like a major deal but I guess not...
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 05-27-2004, 09:02 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Pistons...
you only have a b16a, there is no motor with a b16a sirII, the sirII is the model trim of the civic it was ripped out of.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-27-2004, 03:35 PM
well for couple hundred more you can get aftermarket pistons and bump yoru compression up to 11.5 or somethign around there.
Team Lonely Drivers
Old 05-27-2004, 06:03 PM
Jszy Jszy is offline
Re: Pistons...
B1Sir6A.....how do you run a 12 second 1/4 with only i/h on a b16a?
Im not doubting you at all it just seems a little fast for only having intake and headers...do you have anything else done to the car??
Old 05-28-2004, 03:05 PM
B1SiR6A's Avatar
Re: Pistons...
Crxlvr I actually have a JDM SiR-2 (my motor came stock in the car) I was only telling him that thats the kind of car that the engine came out of...
Jszy nah thas crazy...I wish i was running 12's in the 1/4...Down here (Nassau, Bahamas) our only track is only 1000ft long which means that we're missing out on another 320ft to make a quarter mile so add on about 2 - 2.5 seconds to make up the extra 320 ft and i'll probably be doing high to mid 14's in the 1/4 mile...
Oh yeah my bad I have intake and exhaust not headers I typed the "h" by mistake I guess...
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 05-28-2004, 08:34 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i wouldn't get the ctr pistons. the increase in compression ratio isn't enough to justify getting them.
if you plan on going hard core all motor, Look into getting some 11.5:1 or higher c/r pistons
