Old 05-26-2004, 08:58 PM
cody911911's Avatar
cody911911 cody911911 is offline
3 subs w/ a 2 channel amp?
I got 3 rockford fostgate 10 inchers 150 rms 400 peak 4 ohm impendence what I am wonedering is if I could parallel 2 together (giving 2 ohm load) and then just run the other sub directly at 4 ohms....would they sound diffrent or would this be allright or would it be better to bridge the amp and then just wire nut all the speaker lines into one? what kind of load would this make on the amp?
1st rule of drinking and driving.......you gotta have a beer.....
Old 05-26-2004, 09:14 PM
cody911911's Avatar
Re: 3 subs w/ a 2 channel amp?
http://cgi.ebay.com/ws/eBayISAPI.dll...700431090&rd=1
A highfonics Brutas mono channel....500 watts at 1 ohm. Is that rms or peak? I need 450 rms preferably close. If i parallel them all i get a 1.33 load so that would be roughly 400. Would this make a good amp for my subs?
Old 05-26-2004, 10:31 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
I wouldn't try that, technically it could work, but it's really pushing it. Your best bet is a mono
That Brutus is good, it puts out 500rms @ 1ohm, which would give you around 375 @ 1.33ohm. It could work, but somthing that does 6-700x1 @ 1ohm would work better.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-26-2004, 10:48 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
I am a perminent elemental designs fan, so I say try out the new nine.1. About $268 shipped. Runs 1400watts rms according to the staff.
www.cloudcity.deviantart.com
Old 05-28-2004, 09:15 PM
cody911911's Avatar
this amp is the only amp i have found that runs close to what I need every other amp I find runs well over what my subs are rated for. I don't want to burn them out either. It would be considerably better than what I am using now anyway Do you know any amp that would work better than this?
Old 05-28-2004, 09:27 PM
cody911911's Avatar
Hifonics nemesis 750 rms at 1 ohm 375@2 ohms. Would this make a better choice or would it be to much power? Wouldn't it actually be lower than 750 due to heat and stuff? which would you use? Rockford suposibly underrates its stuff so would it hold up to this?
Old 05-28-2004, 09:53 PM
sr20de4evr's Avatar
750@1ohm will give you [email protected]
That should work fine, 40 watts over the rating per speaker won't make any difference, and if it does those are shitty subs that need to be replaced anyway
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-28-2004, 11:00 PM
Haibane's Avatar
running speakers overpowered will not harm them, unless you are putting distorted power to them. If you run it with the gains to match the voltage and keep the bass low enough you are fine.
Old 05-29-2004, 09:51 AM
gregory1041's Avatar
gregory1041 gregory1041 is offline
Having an amp that has a higher rating than your subs is a good thing. This will give you what they call "head room” meaning that you don't have to turn the gains all the way up to hear the music. Plus if later on you want to upgrade the subs to something with a higher power rating, you don't have to go out and buy another amp.
I keep all of the gains on my amps at about 50%. This gives me a cleaner sound with less hiss and distortion.
If you have to turn your amp gains all the way up to get your speakers as loud as you want, you need bigger amps.
On the other hand, if you put a good amp to cheep speakers, you will get crap. If you put a cheap amp on nice speakers you will still get crap. It’s that whole “your system is only as good as your cheapest component.”
Old 05-29-2004, 12:12 PM
cody911911's Avatar
allrightill go with the nemesis then since its only 20 bucks more. Thanks for the help guys and the bubs shouldn't be to shitty they are rockford punch 3410's
Old 05-29-2004, 02:05 PM
sr20de4evr's Avatar
Re: Re: 3 subs w/ a 2 channel amp?
50% gain does not mean 50% power, in fact it rarely does. In my setup, if I had my gains at 50% they would be clipping very heavily if I ever turned the volume past 20-30 (it goes up to 62). My gains are properly set and they're at about 20%, if I turned it up any higher they would start clipping before I hit the max unclipped volume on the headunit, and if I had them any lower they would never hit max output without the headunit clipping first.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-29-2004, 03:32 PM
cody911911's Avatar
wuld it be even better to go with a 1000 watt nemesis or would this be to overboard?
Old 05-29-2004, 03:59 PM
sr20de4evr's Avatar
It's all in your control. You can stick an amp capable of making 2000rms on a 200 watt rated sub as long as you know what you're doing. If you have a tendency to just crank the gain because it gets louder that way, then you shouldn't be overpowering your subs at all or you'll just end up blowing them.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-29-2004, 04:04 PM
cody911911's Avatar
well I am not looking to have crazy bass like most people I just want good sound quality and I haven't fooled with gains very much yet. I think I would be allright with the 750 nemesis but It wouldn't hurt to have a bigger amp If i upgrade my subs later on or something. What do you think of Hifonics amps?
Old 05-29-2004, 04:25 PM
sr20de4evr's Avatar
Should be pretty solid
Just for reference, in my future setup I'll be using a sub that can handle 1600 watts thermally, but in the box I'm putting it in it can only handle ~800 watts before maximum excursion. I'll be using a 1500 watt amp on it with very conservative gains, mostly for future upgradeability and headroom. As long as you know what you're doing you can use as much power as you want, it also has to do with how the sub's power handling is rated (thermal or mechanical). In your case I would go with the 750w, just to be on the safe side of things, atleast until you really know what you're doing later on.
'01 Black Sentra SE
'05 Silver WRX STi
