Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-26-2004, 04:48 PM
Walleye Walleye is offline
Installing a Kill Switch in a 2000 Corolla?
Well, it has come to my attention that i need a kill switch for my car.
My sister quite literally stole it today. somehow there was a 3rd set of keys set around. I gave the second set to my brother, and i keep the first set.
The reason she stole the car, is that since she's older, she thinks she's entitled to it. She owns a 95 ford explorer, and she crashed it into another car. this is the 3rd car she's pretty much destroyed, in 7 years of driving. the explorer isnt completely totaled, but it'll be several thousand worth to fix it. (2 other cars are the 84 camry, and a 99 corolla)
So, she thinks that because she's out of a car for the meantime while hers gets repaired, she thinks she owns mine. We offered her other options already. an 84 camry, and a 96 windstar. but no, she has to have the 2000 corolla.
I have to do something to keep her from stealing my car continually. I'll start pulling the distributor or doing some other cutoff, till i can get this installed. but i want to do something.
I have all the documentation and everything for the car, and i will probably be putting the kill switch in the door map pocket. (i dont keep anything there anyway. ) if not, then i'll locate it under the dash. I have the pinouts, the electrical diagrams, factory service manuals, etc. So... what should i tap into for the kill switch? anyone have any suggestions on what kind of switch to use? how much current should the switch be able to handle?
Old 05-26-2004, 06:48 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: Installing a Kill Switch in a 2000 Corolla?
Just cut the brake lines
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 05-26-2004, 08:39 PM
Re: Re: Installing a Kill Switch in a 2000 Corolla?
I'd like to be able to drive it tomorrow...
Old 05-27-2004, 05:37 AM
joykill joykill is offline
where did she get the 3rd key anyways? just steal the 3rd key and eliminate the trouble of wiring all that stuff up, or you can just buy her a new car.
671 ISLAND ROOTS
Old 05-27-2004, 12:30 PM
I dont know where she got the 3rd key, and i wouldnt put it past her to have already gone and had a copy made.
Old 05-27-2004, 10:08 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Take all plastic off the console around the key. Find the main power wire. Cut it and wire up each end to a switch. Hide it under the steering column. Not hard.
Old 08-21-2004, 02:41 AM
Iphire Iphire is offline
I was thinking about getting this myself once my car is worth stealing, http://www.4mysecurity.com/products.htm
this way even if she finds the switch she'll need the security key.
Old 10-09-2004, 03:03 PM
Mecha2 Mecha2 is offline
Buy some steel chain and a padlock(combination)
Wrap the chain around the steering wheel to the
brake pedal and lock it tight. Problem solved for
less than 10 dollars!
Old 02-07-2005, 06:13 PM
firedrewski03 firedrewski03 is offline
Just change the lock. Or have some Italian hitmen make her disappear
