Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 01-19-2002, 02:09 PM
nismoboy nismoboy is offline
pulsar engine change !!!!
hey !!!
i was just wondering ....would the GTIRS engine blot straight in to the pulsar GTI ??......do we need to do anything else if u wanna put the sr20det??.....and how much do u reckon it might cost ??
cheers !!
Old 06-26-2002, 07:21 PM
Pulsation Pulsation is offline
engine change
Considering that the gti-r engine is the same configuration (north-south or east-west) it can fit into that engine bay. also if its rear wheel drive then ur gonna have to consider gettin a gti-r drive train. The SR20's are around $1500-$2500 for just the engine or u could pick up a front cut for a bit more.
Old 06-26-2002, 08:21 PM
cadet's Avatar
cadet cadet is offline
there are a couple kicking around Auckland NZ, one has a GTiR SR20 the other has a Bluebird SR20, so it can be done and i think reasonably cheaply. if you dont push it too much you can probably get away with the standard box and radiator but it would be best to upgrade these and the brakes and suspension. from what i hear these cars are very fast, the main problems being wheelspin and torque steer.
do it!
Old 06-30-2002, 03:40 AM
squidgti squidgti is offline
Hello,
Pretty much bolts straight in... but the flywheel and clutch assembly
on the GTIR is a larger diameter than the GTI, and the GTI's
clutch isn't strong enough, so I had to have a custom combo made.
everything else just bolts up, couple of changes to the loom mainly
to do with the injectors (need ballast resistor if using GTIR engine)
and a few plugs need changing/relocating.
Squid.
Auckland, NZ
GTI with GTIR engine
PS, torque steer not so bad, but suggest you get a GTI with
at least a viscous LSD.
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
HELP with N16 Pulsar Service Manual 200sxboy Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 03-06-2009 06:22 PM
1.6 N13 pulsar engine mods? Cam_308 Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 06-03-2005 10:35 PM
engine change/engine wanted 2gooses Wrangler 2 04-12-2005 02:01 PM
