Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-26-2004, 02:43 PM
Icantgetno Icantgetno is offline
B16 swap drop question
When Installed my B16 in my 91 CRX si I had to raise the car for it to be drivable. I have cheap A$$ coil overs and no Idea how much I am dropped at the moment.I want to buy a real set of springs and struts that will perform real nice with my new motor. Ride COmfort is not much of an issue, currently I am running motegi 16's with Yokohama Parada Spec 2's 205/40/16. I also have about 100 lbs of stereo in the hatch(well mounted). Here is the pisser, I live in Vermont and due to frost heaves in the winter the roads get real bumpy. I drive hard in the mountains lots of twisty steep gradient driving where 180 turns are not uncommon. Needless to say the suspension gets a helluva workout. I am hoping to keep the cost under $600. Of course i'm looking for sugestions on combonations to install but my main question is, what is the optimum drop to run with a B16 swap.
Thanks tons,
Old 05-26-2004, 04:06 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: B16 swap drop question
good spring shock combo are H&R, Eibach or Neuspeed springs along with Koni, KYB, or Tokico shocks. The b16 really shouldn't have made that much of difference. But I hear you on the bumpy roads and everything. Any combo out of those 6 will probably be under $600.
Empty Pockets Racing Member #1
Old 05-26-2004, 05:04 PM
96Civic_Coupe 96Civic_Coupe is offline
Banned
yea, i have Neuspeed's on KYB's
Old 05-26-2004, 08:36 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I'd say for your needs and also weight additions, go with Skunk2 coilovers (yes they are a bit stiffer than most others, but handling should be good) and match them to some Koni Yellow shocks.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-27-2004, 05:54 PM
What I have in the car now are crappy coil overs. To Install them I had to remove the rubber pad from the bottom of the top mounting plates, now my suspension rattles. I am hoping to eliminate the rattling with this upgrade, do I need to hit a Junkyard for new ones or will this solve that problem?
Old 05-27-2004, 06:24 PM
BullShifter's Avatar
Get you some Ground Controls w/ custom spring rates & Koni Yellows.
Old 05-27-2004, 08:02 PM
Damn them Koni's are pricey From what I can tell from looking for an hour that package is about 800 at best.... Any Ideas more budget friendly?
Old 05-27-2004, 09:58 PM
Cali Guy
Re: Re: B16 swap drop question
Tein Basic Dampener true full coilovers. Retail for $750, can be found for as low as $600 sometimes on www.groupbuycenter.com
hessemer69 on AIM
Old 05-27-2004, 10:11 PM
GScivic7's Avatar
www.hpautoworks.com
