Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-26-2004, 02:26 PM
Hsmith117 Hsmith117 is offline
Angry Door lock and switches 96
for some reason my passenger door will not go down when press to lock. and on the driver side when you hit unlock the nothing happens. Is this some type of electrical problem. Its weird because the lock button works. Can someone please help...
Old 05-26-2004, 08:35 PM
mabulok mabulok is offline
Re: Door lock and switches 96
You will have to troubleshoot each door separately. If you are comfortable doing this type of work, take the door panel off and check the connections, check for voltage as you cycle the switches, check the door linkage for bent or damaged parts. If you have voltage at the actuator, the actuator is probably bad. No voltage, a relay, the switch or wiring is the culprit. This should be a relatively easy problem to identify as there are only three components to the door lock - switch, actuator, and power/voltage.
