Old 05-26-2004, 12:44 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
A question about putty
I'm doing some modifications with Tamiya epoxy putty (quick type) which I have used quite a bit before. The thing I always find frustrating with it is how hard it gets and subsequently how long it takes to sand out. I've noticed that other people use other types of putty for touchups and finishes.
I'm looking for a putty that is easy to spread out, and easy to sand out. It doesn't matter if it is 2-part or 1-part, although 1-part would be preferable.
I've used Bondo Spot & Glaze (Testors Putty) and really did not like it. It is very crumbly and also shrinks. Very hard to get a nice smooth surface out of. So if you can avoid these properties, all the better.
Thanks for your input.
I work slowly!
Old 05-26-2004, 12:46 PM
DSM-Mark's Avatar
I should add that I have reasonably easy access to Squadron White and Green putty, as well as Milliput, but should be able to find pretty much anything you throw out at me. I live in a big city and have a car, so if it exists, I can probably get it. Thanks!
I work slowly!
Old 05-26-2004, 01:01 PM
lotusmark2's Avatar
lotusmark2 lotusmark2 is offline
Re: A question about putty
I use Isopon P38 easy sand car filler, does the job well, does not shrink and is a piece of cake to sand.
Old 05-26-2004, 04:41 PM
proosen's Avatar
proosen proosen is offline
I use Humbrol putty and dilute it so I can put it on with a brush. Very little needed to correct a problem and therefore little sanding. Dries fairly quick so you can put on another layer if needed.
Niclas
Old 05-26-2004, 04:42 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Evercoat Eurosoft
Or for touch up Squadron White. I used to hate Squadron but its actually pretty good for touch ups and filling joints between styrene.
-Mike
Old 05-26-2004, 04:52 PM
935k3's Avatar
935k3 935k3 is offline
Try this stuff, you will love it.
Dynatron
Old 05-26-2004, 07:22 PM
DSM-Mark's Avatar
Wow. Thanks for the responses. Pretty much every one mentioned I've never even heard of before.
I was at a hobby shop today (before seeing these replies) and bought a tube of Squadron Green for less than $5 CAD. But I can't remember if Green was the good one, or if White was the good one. Anyway, I can always take it back.
Again, thanks for the replies. I may have to do some shopping for some of this stuff. Some of it (eg. Isopon P38) look pretty expensive though.
I work slowly!
Old 05-26-2004, 07:23 PM
DSM-Mark's Avatar
Re: Re: A question about putty
Niclas
What do you dilute it with?
I work slowly!
Old 05-26-2004, 08:05 PM
bvia's Avatar
bvia bvia is offline
The eurocoat and dynatron are good.
I personally use 3M Piranha
http://products3.3m.com/catalog/us/e...er/output_html
hth,
Bill
Old 05-27-2004, 01:57 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
I'm waiting on some Tamiya Smooth Epoxy Putty. I'll tell you guys how it goes.
