Old 05-26-2004, 11:33 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
front engine mount
Just wondering, my front engine mount insert is pretty much shot (can see it moving when blip throttle), are they cheap to replace? I just requested pricing for part at dealership. Do I need the whole mount or just the insert? And installing it, is this right?... jack up front end, place jack under bottom of engine for support, loosen bolts on motor mount, replace with new (insert or whole mount), torque to spec, remove jack from under engine, lower car and drive away happy. Thanks.
Old 05-26-2004, 12:07 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: front engine mount
some are pressed in, require a hydrolic press or arbor press or install and remove, some arnt, I couldnt tell you without looking. If you replace the whole mount you dont exactly what you just said.
Old 05-26-2004, 12:32 PM
If the whole mount is inexpensive, I'll just replace the whole thing. Thanks for the info.
Old 05-26-2004, 01:48 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
http://store.summitracing.com/partde...S%2D16%2D1104R
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
