Old 05-26-2004, 10:20 AM
zboom86's Avatar
zboom86 zboom86 is offline
Send a message via AIM to zboom86
Question door prob.
I was told in order to rebuild my door hinges I have to cut the original ones out. It looks like that might be possible, but there has to be a nother way to do this.
Old 05-26-2004, 10:58 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
parts stores have a "HELP" section with everything from window winders to exhaust flange springs.
they sell replacement door pins and bushings, takes about an hour to fix
Old 05-26-2004, 12:31 PM
zboom86's Avatar
Re: door prob.
Well i need to know if i have to cut out the old door pins in order to put the new door pins and bushings
Old 05-26-2004, 12:33 PM
zboom86's Avatar
Re: door prob.
I can figure out how to do it, but at the top of the pins there is a strip that holds it in and napa told me that i would have to cut it
Old 05-27-2004, 12:59 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: door prob.
Do you want to put new Hinges in? or replace the pin and bushings?
There should be a metal c-clip type of thing at the bottem of the pin that can be pulled off.. Then you pull the pin out and the bushings will fall out..
Good to have a buddy hold the door, or find something to hold the door up
1991 Camaro Z28
Old 06-03-2004, 01:25 AM
zboom86's Avatar
Re: door prob.
Hay we are talking 1971 camaro
I was told that they had to be cut out do they
Old 06-03-2004, 01:28 AM
zboom86's Avatar
Re: door prob.
all check, but if i remember right there is a head on the bottom and a notch at the top but the bottom could be a c clip all take a look again
