Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-26-2004, 07:26 AM
BboyFlipRoc BboyFlipRoc is offline
Question Clutch Adjustment?
Can you perform a clutch adjustment on a '98 Saturn SL? If so, would it be possible that someone could give me the procedure?
Old 05-29-2004, 03:58 PM
Lucas1 Lucas1 is offline
the clutch is hydraulic. it is self adjusting. and not adjustable.
Old 05-30-2004, 02:57 AM
Is it normal that you can't shift into gears occasionally like depending on whether your on unlevel terrain, such as a hill or shit like that? Also, not too long ago, it was like raining out and I like could not get it into gear.. I seriously had to put like all my strength into it... Thought I was going to break the fucker... Anyone?
Old 05-30-2004, 03:31 AM
public's Avatar
public public is offline
Hydraulic clutch master or slave cylinder may be going bad. Is it hard to move the shifter or hard to push the pedal? Can you double clutch and make it easier?
Old 06-07-2004, 04:58 PM
jaydee23 jaydee23 is offline
help
if anyone can eloborate more on this issues that would be great..ive got a 96 sl 2 and it took three days of the stick getting harder and harder to push into gear when finally today it just will not go into gear..im a diy selfer and i need to know where to start..bikes im more familiar with but i need to give this a shot cuz funds are lo9w..(bikes in the shop also!)
Old 06-08-2004, 06:46 PM
how many miles are on you car?
is there any fluid in your clutch master cylinder?
if you have more than say 80k on your car and your having shifting problems, you should probably just replace the clutch and hydraulics.but then, if there is a leak in your hydraulic system you might want to just start with that.
Old 06-09-2004, 07:25 PM
thanks the clutch hyd cylinder had no fluid in it so i guess i have a leak but see no fluid anywhere and the car now shifts fine after adding fluid..little sticky but fine none the less.. we will see what happens in the future and if i experience the same problem i guess i should start looking for the leak or replace the clutch master cyclider right?
Old 06-09-2004, 10:09 PM
i would defenitley replace the master/slave cylinder. on saturns it is all 1 unit. if you get the factory one its already full of fluid and bled. i dont know whats available aftermarket.
