Old 05-26-2004, 02:34 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Question Weird Problem...Read please
OK guys and girls... My CRX just started doing the weirdest thing. Sometimes I get in and turn the key and it cranks and cranks and just won't kick over. Then, if I push it or let it roll a little bit, it will start. Could this be something wrong with my fuel pump? It almost seems like the fuel pump is not getting fuel until I let the car move so the gas splashes around a little or something stupid like that. Any ideas? Anyone had this happen ever? I appreciate all your help!!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 05-26-2004, 02:38 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Have you checked for spark? Is it the starter? Maybe a sensor problem... Do you get a CEL?
So you're not bump starting it, you're just letting it roll a few feet and then trying to start it? weird...
Unless the car is in gear while it's rolling, it wouldn't spin the crankshaft or anything, so I don't understand why that would allow the car to start.
Old 05-26-2004, 03:07 AM
4GZChatch's Avatar
Re: Weird Problem...Read please
The starter turns over fine, and I am getting spark, cuz it will eventually start, and I am getting no CEL, so I don't think it could be a sensor problem. No, I'm not using the clutch to start it, just sorta letting it coast a few feet then stepping on the brakes. The only thing I can come up with is that it's a fuel delivery issue, where the fuel is not getting picked up by the fuel pump or something. IDK, it's real weird to me too.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 05-26-2004, 05:40 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
fill up your tank and try and start it, and then it will eliminate that possiblity
Team Lonely Drivers
Old 05-26-2004, 09:45 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
So the car isnt in gear when you roll it?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-26-2004, 11:17 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
fuel filter???
like someone said before fill it right up with fuel, when was it last serviced, oil filters etc ?
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
