Old 05-26-2004, 01:04 AM
GSX21 GSX21 is offline
turbo questions
im getting the 16g turbo upgrade for my gsx i have all the basic parts(intake, exhaust, new boost gauge, new plug wires, new greddy blow off, new boost controler) Do i need to get a new FMIC before i get the 16g. Even if i run the turbo close to stock boost levels?
-GSX21
Old 05-26-2004, 02:32 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: turbo questions
Stock FMIC is fine for 16g turbo. A FMIC will allow you to max out a 16g with manageable knock, but you dont NEED it to run. Just be sure to keep boost relatively low (~16 psi) unless you are datalogging. If you have a datalogger, or can borrow one, you can gradually raise boost until you knock, run out of fuel, or both.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-26-2004, 02:49 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: turbo questions
he means the stock SMIC
Old 06-04-2004, 05:14 PM
cblevins cblevins is offline
Re: turbo questions
You can run the SMIC with up to 16psi like stated before. If you're running on a hot day, be careful with raising the boost. The shitty stock smic will heat soak in a hurry if driven hard.
