Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-25-2004, 11:25 PM
Jszy Jszy is offline
ls/vtec step by step guide?
Does anyone know where to find a step by step guide to building an ls/vtec? If not, does anyone know of any good books that can walk you through it?
Old 05-27-2004, 06:05 PM
Re: ls/vtec step by step guide?
bump
Old 05-28-2004, 09:49 AM
almxdupintegra almxdupintegra is offline
There is no real book on doing an LS VTEC set up. Its pretty much just changing the head and adding some dowel pins. Theres more to it though. Head gasket, wiring, torque
Old 05-28-2004, 02:49 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
http://hondaswap.com/forums/index.php?showtopic=33559
http://www.angelfire.com/dc/lsvtec/lsvtec.html
http://www.importtuner.com/tech/0104...ein/index.html
http://honda.hybrids.jp/b20tech/index.shtml
Those sites all give you a pretty good idea of what to do. The last one is actually a b20, but it's the same process.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 05-30-2004, 01:14 PM
Thanks alot 95TegSE, this helps a lot.
Old 06-01-2004, 03:01 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-01-2004, 03:23 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
I didn't read any of those site, yet, but do u need to get a new ECM?
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 06-01-2004, 03:37 PM
Re: Re: ls/vtec step by step guide?
yes since LS PR4/P75 ecu doesn't have vtec
Old 06-01-2004, 05:37 PM
Are the ITR and GSR heads the same?
FOR SALE
Old 06-01-2004, 06:26 PM
95TegSE's Avatar
No, ITR and B16 heads are the same, with the ITR head just having a beefed up valvetrain and a factory port/polish.
Old 06-02-2004, 05:01 AM
What ECU would work best for a LS VTEC?
Old 06-02-2004, 06:02 AM
95TegSE's Avatar
a P72 (GSR), P73 (ITR), or chipped P28 (SOHC VTEC) work best from what I've heard. The USDM ITR ecu is only OBD II though, but I believe there are some JDM P73s that are OBD I.
Old 06-06-2004, 02:39 AM
I was reading something about the Vtec cylinder intake manifolds having like 2 differen sets of runners, one that opens up when the vtec engages. Is this true, because i did actully see a picture of it. So if i was doing the swap, would i need the new manifold
FOR SALE
Old 06-06-2004, 04:22 AM
95TegSE's Avatar
The GSR intake manifold is the one with the dual runners. You'll need the new manifold if you're going with any VTEC head though.
Old 06-06-2004, 11:42 AM
Unless your using the same manifold that came with the head.
FRIENDS DON'T LET FRIENDS DRIVE STOCK
