Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-25-2004, 09:32 PM
Mr2Xer Mr2Xer is offline
ct-26?
Does the ct-26 turbo for the old supra fit in the mr2 turbo? If so, does it bolt right in? Any other information on these turbos or the installation would be greatly appreciated.
Old 05-25-2004, 09:50 PM
Ok, I found out that the two turbo's are different in that the Mr2's is dual entry, and the supra's in single entry. The supra's is also less restrictive and can support more hp. It also doesn't fit the Mr2's elbow. Does anyone know how to install it, or someone who makes modified elbows that would allow it to fit?
Old 05-26-2004, 12:42 AM
node node is offline
Re: ct-26?
I am running the turbo on my 2 here ya go
http://www.mr2oc.com/showthread.php?s=&threadid=18213
Old 05-27-2004, 11:06 PM
ATSAaron ATSAaron is offline
Send a message via AIM to ATSAaron
Re: ct-26?
You can swap the center sections and get a small upgrade. However the Supra's exhaust housing will not bolt the the MR2 elbow.
Aaron
Old 05-28-2004, 12:41 PM
Re: ct-26?
Well aron your kinda correct. Here is my description of my install. Its not too hard to do
> There are several changes that need to be made in
> order to use this
> turbo on the MR2. First you need to remove the
> single entry supra
> exaust housing. Next you need to remove your twin
> entry housing from
> your MR2 turbo. Keep the WG acutuator attached to
> the MR2 WG.
> Removing the housings is a PITA and it WIll take you
> a while since they
> are press fit togeather as well as clamped
> togeather.
> Next there is a "clocking pin" on the center section
> of the turbo that
> makes sure the turbine housing only goes on one way.
> You need to
> remove this.
> Get some good needle nose pliers and remove the
> compressor snap ring.
> Take out the clocking pin or pins from the
> compressor housing. DONT
> take the compressor housing off! you could damage
> the compressor
> easily.
> Compare the turbos side by side and turn the
> compressor housing untill
> it is orented correctly. Do the same for the exaust
> housing. Dont
> worry about being too exact it will still fit if
> your off by a degree
> or two. Use a rubber mallet to force the compressor
> housing back onto
> the center section. You may want to clean up the
> surfaces where they
> mate up.
> Take all the oil feed and return lines off of your
> MR2 center section
> and swap to the supra turbo.
> Pull the WG actuator out and over the compressor
> housing. Use 1 bolt
> to hold the actuator instead of 2. dont worry there
> is a bend in the
> actuator bracket that holds it in place even with
> one bolt.
> Install the turbo and your done.
> I have acces to a few ct-26-A's with the larger
> compressor wheel if
> your interested. This is what im running. I get
> full boost by 3200
> maybe eairlier. I still have the secondary cat in
> there too, so I
> guess spool could be a bit quicker.
Old 05-28-2004, 12:45 PM
Re: ct-26?
> Pics of the dissasembly here
> http://bulldog.unca.edu/~jmpersek/car.html
