Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-25-2004, 08:54 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
help! major prelude problem!
tonite i was sitting at a stop light waiting for the light to turn green. as i took off i noticied a shuddering coming from, i believed was the driver side of the car. i belived it to be a flat tire. when i got out to check everything was fine but my exhaust sounded different, it sounded literally comin out in "put put put" with spce sin between. i then cheked under the hood. the engine seemed to be moving an awful lot for it to be only idling. also i heard a slight constant ringing noise comin from near the fuel injectors. i decided i needed to get home and drove home. while driving i noticed a slight jerking not constant but rather erratic with spaces in between the jerking. the jerking seemed to be coming from the engine again, however my rpms stayed level. also my accelration has gone to shit i feel like im driving my moms mini-van. i have no clue what could be wrong , but my first thought was to the transmission. please help
"You can't do anything worth doing in life without taking a chance" - me
funny shit
Old 05-25-2004, 10:45 PM
510prelude 510prelude is offline
Re: help! major prelude problem!
sounds like you might have lost compression in one of your cylinder's, see if there's any oil leak's around the valve cover or by the spark plugs
of course i could be completely off and wrong but worth a check.
Old 05-25-2004, 10:59 PM
crzyCollegeKid crzyCollegeKid is offline
well....theres no way it could be an engine mount. you might have bent a valve or something and lost compression like 510prelude said.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 05-26-2004, 07:41 AM
bump please any ideas
funny shit
Old 05-26-2004, 12:16 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
compression, its soudns like you lost a cycnder man.
Old 05-26-2004, 01:53 PM
well if it is compression, i guess im going to need a whole new engine, unless tehre is a cheaper way to fix this problem. any ideas u guys?
funny shit
Old 05-26-2004, 03:13 PM
yeah lost compression lost cylinder maybe new piston rings no need for a new engine, did you do the oil leak check i told you to do? it there are leaks around the sparks probally need new piston rings
Old 05-26-2004, 03:20 PM
nope no oil leaks. i havent seen any oil leaks or fluid leaks anywhere on the block. can i do more damage to my car whiel running on only the 3 cylinders
funny shit
Old 05-26-2004, 03:30 PM
i dont think you could, my friend has been running on 3 cylinders in his tercel for about 2 years now
Old 05-26-2004, 07:06 PM
SRV BOY SRV BOY is offline
Maybe check ur O2 sensor! just an idea
Old 05-26-2004, 09:07 PM
replaced teh o2 sensor last month along iwth my cat. plus no black smoke or residue so im not running rich
funny shit
Old 05-30-2004, 08:22 PM
Bobiii84's Avatar
Bobiii84 Bobiii84 is offline
Send a message via Yahoo to Bobiii84
So u have a 92 lude. Ok. First of all, when u say running rough, please elaborate. I have an 84 prelude with tons of vaccuum hoses. Shortly after I bought the cart it began to idle badly every once in a while usually when cold but not always. I was and am very into cars but to me it felt like my timing was off or a cylinder was not firing correctly etc. This was not the case however. It turns out that it is idling rough for whatever reason, but feels like it is misfiring. I would just consider the possibility that this could be the case for u. Remember, the people on this site only go by what u say is wrong, and may not be correct. No offense guys! Just make sure u check out everything u can and good luck!
Old 05-30-2004, 08:42 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
What do your spark plugs look like? Could be a good indicator of what is wrong.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 05-31-2004, 12:01 PM
partyhardryan16 partyhardryan16 is offline
i dont know much about this kind of thing, but if it was a cylinder wouldnt his rpm's be higher than usuall and when its idling wouldnt the rpm's be higher?
Old 10-12-2004, 03:55 PM
Howdawg Howdawg is offline
It could be your injectors...
Check your injectors, To check, you can use a mechanics stethoscope and use it to listen to each individual injector when the engine is on. Or when the engine is off, remove the metal clasp that holds the wireharness to the injector, do this for all four injectors. Next start the engine and one at a time pull of a harness and see if there is a change in the smoothness of the engine. If the engine idle becomes worse, replace harness and try the next one. If you pull one out and it doesn't change anything with the engine idle, you might have found your prolem injector. Also, it is possible that two injectors are not working. Dont just throw you injectors out, the problem could be the absence of an electrical signal to the injector. Anyways, just try it out.
