Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-25-2004, 07:52 PM
carlos_colion carlos_colion is offline
Question Gas Mileage
Does somebody knows what gas mileage I can get in the 98 Dakota 2.5L Manual 5 speed?
Because my fuel gauge does not work and I want to use the trip mode to control my gas usage and not to ran out of gas, I just fill up my tank and put the trip mode in zeros.
According with what I read in this forum about this dakota model the gas tank is 16 gallon I just need to know how many miles I can put in the truck before ranning out of gas.
Old 05-25-2004, 08:27 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Gas Mileage
I would start with filling up, zeroing the trip odometer, doing 300 miles, and then filling up and seeing how many gallons of gas you have to put in. Then you can figure out how much gas you must have had left in the truck, and then you can figure out about how far you can go safely with one tank of gas.
Old 05-27-2004, 10:43 AM
Re: Gas Mileage
So I can go 300 miles without ranning out of gas?
Old 05-27-2004, 03:19 PM
BleedDodge's Avatar
Re: Gas Mileage
Yes.
Old 05-30-2004, 06:17 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: Gas Mileage
Well, whoa!,
If somethings up with the 2.5, you might not get 300 miles out of it!
Why don't you fix the fuel sender? could just be a loose wire, or bad ground.... just drop the tank and look, but if the guage is just broke, replace it!
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-31-2004, 08:05 PM
BleedDodge's Avatar
Re: Gas Mileage
It should do at least that. My truck was running in an open loop and it would do more than that, and that was while running it into the ground. If it couldn't do 300 miles then I'd say he was idling it all night in between driving days...
