Old 05-25-2004, 06:33 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
wring
if I get a 2ohm stable amp stereo , how do I wire 4 4ohm speakers into it, so that the speakers are 4 ohm and the amp is 2?
Old 05-25-2004, 07:58 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: wring
parallel
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-26-2004, 05:02 PM
AZFlyingDiver AZFlyingDiver is offline
Re: wring
Yep - 2 4-ohm speakers parallel (basically hook positives together and negatives together) will look like 2 ohms to the amp. Sounds like you want to hook 2 speakers together this way for your left channel and the other 32 speakers this way for your gith channel. You won't be able to fade the speakers, though (you'll need a 4-channel amp for that)...
Old 05-26-2004, 06:17 PM
jdrumstik's Avatar
Re: wring
so should I wire the secound speakers off of the first sets terminals, or gboth speakrs to the same map terminal?
Old 05-26-2004, 09:31 PM
sr20de4evr's Avatar
Re: wring
Either way would work just fine, it's probably easier to wire both speakers to the amp terminal though unless the speakers are mounted right next to each other.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-27-2004, 03:45 PM
jdrumstik's Avatar
Re: wring
sweetness, when I was like 12 I wanted surround sound so i wired 4 8 ohm speakers into a crappy aiwa cd/reciever bookshelf unit, I pulled 4 ohms out of that thing! and it never broke! wow, how great is knowlege?
