Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-25-2004, 05:16 PM
radvra radvra is offline
97 Aurora A/C failure...electrical?
I am told there are 8 different electrical sensors that could impact AC function...are their any that fail consistently that I can test/replace?
My 97 was working fine with cold air...then, next day I am getting warm air...any ideas on a fix? System checks out with a strong charge...what next?
Car has 155K miles, and I have done nothing but regular oil changes and maintenance. I am told the Cadillac Northstar has on board diagnostics for electrical sensors, but the Aurora doesn't. What do I look for?
This car has been awesome and I would buy another one if/when this one dies...just want to keep it clean and in working order.
Thanks in advance to all you Aurora experts/fans.
Old 05-25-2004, 05:18 PM
97 Aurora Power antenna sources/prices?
Can anybody recommend a good source?
Old 05-25-2004, 06:24 PM
Spinman's Avatar
Spinman Spinman is offline
Re: 97 Aurora A/C failure...electrical?
You will need to find someone who has an OBDII scanner with HVAC capabilities. They can scan the system and check the self diagnostics to determine if anything is showing a failure. W/O the scan, I do not believe you can check the system yourself.
What a pain - my 1990 Chevy had self diagnosis capabilities - can't believe the Aurora did not include this feature...
Old 05-25-2004, 07:02 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
All 95's are like that...not just the Aurora, its so easy with the OBDI you can use a paperclip :P
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 05-26-2004, 05:16 PM
bustedratchet bustedratchet is offline
Re: Re: 97 Aurora A/C failure...electrical?
Check the A/C clutch hub it might be ka-poot. It might be engaged but not spinning the insides of the compressor.
