Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-25-2004, 02:34 PM
alphalanos alphalanos is offline
rotating tires
what is the correct way to rotate tires on a FWD car?
96 EJ6. Future home of boosted B18C1.
Old 05-25-2004, 03:17 PM
marchi1's Avatar
marchi1 marchi1 is offline
Send a message via MSN to marchi1 Send a message via Yahoo to marchi1
Re: rotating tires
Mine rotate all by themsleves. See the engine drives the transmission, either manual or automatic, which in turn drive the half shafts, each one drive its own independent wheel. this rotates the wheels round and ound causing you to go forward......
Actually it only matters if you have directional tires. Some people say front to back(directionals must be done this way, can also do non-directionals this way), some say in an X figure (no directionals only). I have always done the X, but it doesn't matter as long as you are happy.
Old 05-25-2004, 04:52 PM
CapriRacer CapriRacer is offline
Re: rotating tires
I think you'll find that most tire folks will opt for the "Mod X" pattern - drive tires stay on the same side, freewheeling tires cross.
Old 05-26-2004, 01:20 AM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Re: rotating tires
I agree that is how it is usually done, if you want a diagram or picture, try looking on the internet.
Old 05-26-2004, 10:45 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Here's a link to some handy diagrams:
http://www.tirerack.com/tires/tirete...ral/rotate.jsp
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
