| Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security. |
Applying vinyl to cloth seats
Ok i got one more vinyl question then i'll leave it alone. I went to a fabric shop yesterday and found some cheap vinyl fabric. I wanted to know how i would go about redoing some racing seats i bought in vinyl. Is it just a matter of sewing the vinyl to the seat? Or is there some other way it is done? I'd rather not spend $250 to get two seats redone in vinyl as i really like to do everything to my car myself. I appreciate any ideas or help.
Re: Applying vinyl to cloth seats
i was wondering the same thing. hopefully someone can help us out.
All seats are put together a little differently so there is no way for me to tell you exactly how to recover your seats without actually seeing them.
What you should do is start by taking your seats apart. Depending on how your covers are held on to the seats you will need to either unhook the plastic clips that hold the cover on underneath, or cut the hog rings. Peel the cover off paying special attention to how it comes apart ( you will be reversing the process later). Once the cover is off make sure that there is some kind of reference mark on the seam allowance (the 1/4" allowance of fabric that is on the inside of the seam). If not, make some marks by taking a small pie shaped nip out of the seam allowance every 6" or so (these marks will help you line up the pieces of vinyl when you sew them together again). Once this is done, use a razor blade or seam ripper to cut out all the stitching. Mark all of the pieces as left side, right side, top, seat, back, outside back, etc. Take all of the pieces that you took apart and arrange them on your new vinyl. Usually vinyl will have a backing on it that will allow it to stretch more in one direction than the other (unless you are using really cheap vinyl). Arrange the pieces on the new vinyl with the "stretch" going up and down. You can use a ball point pen to outline the pieces before you cut them out. Be sure to mark all of the reference points on your new patterns! Also, DO NOT use a permanent felt marker to trace your patterns because over time it will bleed through the vinyl! From here it is just a matter of sewing it back together. If your seats have piping (the bead of vinyl sewn into the seam) then you will find it easier to use some pre-made vinyl piping. This can be found at an upholstery supply warehouse or possibly at larger fabric stores. If your original seats have foam backing on the vinyl then you will need to pick up some 1/4" or 1/2" mesh backed foam. The mesh backing allows you to sew it without the thread cutting through the foam and allows it to feed easier through the sewing machine. You will also need a can of spray adhesive in order to glue your new vinyl patterns to the mesh backed foam (this makes it easier for a beginner to keep things lined up). After cutting out the new foam backed patterns you will need to sew around the perimeter of the pattern/foam using a 1/8" seam allowance. This will keep the foam and vinyl permanently attached as you handle it. The piping will need to be sewn in at the same time as everything else. Using a POLYESTER UPHOLSTERY THREAD and the LONGEST STITCH LENGTH on your sewing machine, line up all of your reference marks then sew everything back together using the same seam allowance measurement as the original. Note: Vinyl will not usually feed evenly through the sewing machine, one side will stretch more than the other throwing your patterns off (even with a walking foot sewing machine). One trick that I sometimes use to solve this problem is to staple the vinyl together inside of the seam allowance. This is more accurate and easier than pinning, just remember to pull the staples out after you sew it together. Also use the longest stitch length possible, otherwise the sewing needle will perforate the vinyl causing it to tear where you sewed it! Once everything is sewn up then slide the new cover on and check the fit. If everything looks good then put it on! Sometimes you will need to glue or clip parts of the new cover in order to keep concave/convex curves in place, just follow what the original cover did. Then you can either hog ring your new covers on if that was the way they were originally attached, or you can reuse the plastic clips that were sewn onto the original cover (if you reuse the plastic clips you will need to sew them on before you start putting the cover on). A couple of things to keep in mind: 1. Get a "how to upholster book". You can usually find these at your local book store in the automotive section. 2. Cheap vinyl will not last very long. I used cheap fabric store vinyl when I recovered the seats in my first car when I was 19yo. This vinyl only lasted about 1 year before it started to crack, crumble and disintegrate. Use marine/automotive grade vinyl! This vinyl is UV treated and is better quality, it costs more but it's worth it! 3. Use a high strength/high temp adhesive. Otherwise the glue will release in high heat. You can probably get away with using 3M high strength 90 (found at larger hardware stores), but DO NOT use 3M 77, 3M 74, or anything from the fabric store, even if it does say "foam/vinyl adhesive"! 4. Sewing piping. I could write a whole chapter on how to measure, cut and sew piping (aka welt/welting and cord/cording), but I didn't feel like going into any great depth on the topic since it really is easier for a beginner to use the pre-made stuff. 5. Every seat is different. So these are just general tips for recovering your seats. These tips are also given assuming that your seat foam is in good condition. 6. $250 is a really good price for the reupholstery of 2 seats! That's about how much I charge for 1! Last edited by lxndr; 06-14-2004 at 06:12 PM. |
