Old 05-25-2004, 01:36 PM
jgoertz7 jgoertz7 is offline
clutch problems
okay, I put a d15b vtec in me 88 crx si. I kept the si tranny, and used the same clutch. the clutch was still in good shape. I followed my Haynes manual step by step, but after I installed the tranny/clutch my clutch won't engage. I put the car in 1st gear and I can still push it like it was in neutral. HELP!!!!
Old 05-26-2004, 02:05 AM
Re: clutch problems
does anybody have any ideas?
Old 05-26-2004, 05:44 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
is there resistance on the pedal or does it go straight to the floor easy ?
Team Lonely Drivers
Old 05-26-2004, 08:26 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
IT sounds like either your clutch cable or your shift linkage is not hooked up right
KoRnSaQ
Old 05-26-2004, 09:36 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-29-2004, 02:06 PM
ATLien ATLien is offline
Re: clutch problems
I seem to be having a clutch prob as well. Replaced left and right CVs yesterday and had been having funny sounds coming from clutch. Today, clutch went out altogether. At least that's what it seems. I hope someone that knows something will visit and be willing to offer advice. The CV job was pretty easy but I don't know much about clutches.
My specific symptoms:
1. Shifts in and out of gears without having to press clutch.
2. Doesn't engage when I give gas while coming off clutch.
3. While idling, I hear slight rattle.
I was planning on buying the clutch set from the auto store. It contains Disc, Pressure Plate, Throw-out Bearing, Pilot Bearing/Bushing & Alignment Tool; Cover Type: Diaphragm; 8 3/8" Clutch, 20 Spline, 7/8" Hub
Is it possible that I only need to change out the cable?
Any help at all would be greatly appreciated. Anyone that knows anything. Even if only resources for me to learn more myself. Thanks in advance. I'll be checking regularly so any help provided will not be in vain.
ATLien
Old 05-29-2004, 02:10 PM
Re: clutch problems
Also, if you've performed this type work, how difficult would you judge clutch work to be?
ATLien
