Old 05-25-2004, 11:11 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
throttle body mounted mas
hey i was working on a 97 ford contour the other day and noticed that the mas on it is a inline style mounted in the intake tube. what im wondering is whether anybody knows what kind of car has a inline mas with the right sensors to adapt and mount at the throttle body of a 1g turbo so you can vent to the atomosphere right. also i need to know whether the computer will work right when its getting pressure and temp reading after the turbo instead of before. just wondering because a junkyard mas from some other kind of car has got to be cheaper then any other way we have to vent
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-25-2004, 11:12 AM
Re: throttle body mounted mas
oh btw the contour was a 16v zetec 4 cylinder and the mas had 3 wires coming out of it
-1stGenRocks-
Old 05-26-2004, 02:48 AM
kjewer1 kjewer1 is offline
AF - Advisor
Yes, its called the MAF Translator, and uses GM 3" or 3.5" MAF. YOu can buy them from www.fullthrottlespeed.com (forums at www.fullthrottletech.com) and www.slowboyracing.com, for example. Search for "MAFT" on the various DSM forums, and you will get more info than you want
Hope that helps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-26-2004, 03:23 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
i have a simular question reguarding the MAS being next to the throttle body... if you were to move the MAS right before the throttle body would that solve the richness problem with venting to the atmosphere, right now i dont have the problem but if it occurs in the near future or if someone else would like to vent their BOV would it work? just something i have been pondering and trying to find info on for awhile now but since there is already a simular thread i figure why not ask! if no one has heard anything about it or kevin if you dont think it will fuck with my motor i think i am goin to try it just to see what happens! anyways any input is greatly appreciated!
Old 05-26-2004, 05:50 AM
AF - Advisor
You cant pressurize the stock MAS, thats why no one has done this. Without getting too far into Karmen Vortex theory, here is how the stock MAS works. There is a restriction in the MAS that creates turbulence, in the form of recurring Karmen Vorteces. These are "counted" by a sensor in the MAS. In this way the VELOCITY of the air in the metered section can be extrapolated. The cross sectional area of the sensor is known (unless you hack it, thats why hacking htrows off the readngs) so you can come up with some volume measurements. The MAS also has temp sensors and pressure sensors which allow the ECU to convert the information from the MAS into an air MASS. Hence the term, Mass Airflow Sensor.
You cant setup the karmem vorteces if the air is pressurized.
The MAF used in the conversion is a Hotwire sensor, which uses the speed-density theory. A hot wire is suspended across the sensor. As air passes over it, it carries away some of the heat from th wire. The voltage/current reqired to maintain the temp of the wire is measured. The good thing about this system is that everything affects the temp of the wire. Speed of the air changes? more or less heat will be carried away. Temp of the air changes? More or less heat will be removed. Density changes? higher density means more molecules to remove heat, and vice versa. Hence the speed-density terminology.
This sensor CAN be pressurized, since presure is accounted for in the measurement.
Hope that helps answer some questions.
Kevin Jewer
Old 05-26-2004, 01:17 PM
EclipseRST's Avatar
Banned
holy shit... i had to read that 6 times before i understood that! but now i get it... thanks!
Old 05-26-2004, 03:16 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: throttle body mounted mas
i love it when Kevin drops some serious knowledge on us...
Old 05-26-2004, 04:00 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
LOL.... 7 times.... and still reading.
06 Charger SRT-8 black.
Old 05-26-2004, 04:12 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Kevin is pure genius.
Old 05-26-2004, 04:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
humm, excuse me while i go get my dictionary
DSM geek
Old 05-26-2004, 04:44 PM
the funny thing is that he probly wrote that in like 2 minutes, and it took most of us 10 to comprehend it...
Old 05-28-2004, 10:10 PM
AF - Advisor
MAybe its so hard to understand BECAUSE I tossed it together too quickly... Hmmm I know I have written somehting up before on the subject, if I think of it later I'll look for it.
Kevin Jewer
Old 05-29-2004, 12:24 AM
i think you can make a living by giving lectures already Kev.
