Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-25-2004, 10:01 AM
AuroraXtreme AuroraXtreme is offline
Question VATS ignit. key resistance??
Does anyone know what the "resistance value" or "ohm value" is for our ignition keys (95 Aurora in particular)???? I'm buying some spare VATS keys and need to know the value. Here's the instructions I got from an Ebay seller:
How to determine the Value of your key?
By chance you may know what vats key you now have. Most people do not. There are basically two ways to determine what vats key you have. Remember, there are 15 differrent posobilities. First, your key can be " read " in a vats tester. Most locksmith have these readers, and don’t change anything to tell you. If you are in my area locally, I’ll be happy to read your key for you. But I realize most people are not in my area. But there is a way for you to read the key value yorself. If you have a Volt Meter you can test the OHMS ( The Value ) of the chip yourself. Just set your Volt meter to check OHMS, Take each leed and place it on each side of the " chip " on your key. A number will appear. Take that number on your volt meter and apply it to the OHMS chart below. Keep in mind that it may not be exact. Just pick the closest value to your reading. I do realize that some of you don’t even know what a Volt Meter is, not to mention having one. So there is a great alternative for you. Just take your key to a Radio Shack, or your local Auto Mechanic. Ask them to do as I described above. The vin number will not help.
Here's the chart:
VATS # OHMS
1———— 0.402
2———— 0.523
3———— 0.681
4————-0.887
5————-1.130
6————-1.470
7————-1.870
8————-2.370
9————-3.010
10————3.740
11————4.750
12————6.040
13————7.500
14————9.530
15————11.801
So which one do we have?
Old 05-25-2004, 11:30 AM
dred98's Avatar
dred98 dred98 is offline
Aren't the key resistances different for each car ?
Your keys for a 95 Aurora may not be the same as someone elses 95 Aurora.
Take it in to a GM dealer - they should be able to check your keys and tell you.
Dark Red '98 - Autobahn - Airbox Mod - Sunroof - Cool Blues
http://www.howardm.net/dred98/aurora.php
Old 05-25-2004, 03:05 PM
scudballs scudballs is offline
It could be one of any of those. Is your old one bad or broke? All you have to do is take an ohm meter and ohm it out. Unless of course its broke! That's what I did. Then I soldered a resistor right to the Pass Key II module. Don't need one on the key now!
Old 05-27-2004, 03:30 PM
ugsrich ugsrich is offline
The vehicle may be equipped with any one of the aforementioned resistance values. Each vehicle’s VATS module is assigned one of the resistance values indicated in the original post. Each key “chip” for that vehicle matches the resistance value of the vehicle’s VATS. Your assertion is 100% accurate – my ’95 Aurora resistance spec. may be different than another’s or it may be the same (there are 15 different resistance values). Of course the key itself is also different and will not properly “trip” the tumblers in the lock cylinder. The VATS is designed to keep a thief from simply breaking the lock-cylinder to start the vehicle. If the VATS does not “see” the correct resistance value it does not allow current to flow from the ignition switch through to the starting circuits. It’s a very simple system to slow-down a would-be thief.
Old 05-27-2004, 09:08 PM
dsatt12 dsatt12 is offline
Re: VATS ignit. key resistance??
You know, I did a remote start on my 93 Bonneville some years back with the same system. I seem to recall all of those values being in K ohms, not just ohms, but could be senility setting in too. I am pushing 30 you know...
