Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 05-25-2004, 09:50 AM
fc82703uk fc82703uk is offline
Send a message via AIM to fc82703uk
DOHC Throttle Body vs SOHC Throttle Body
Is there a difference in the throttle bodies on the DOCH and SOHC. FYI i own a 98 R/T. Thanks
Old 05-25-2004, 11:42 AM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
Re: DOHC Throttle Body vs SOHC Throttle Body
I know that the tb from an auto sohc is bigger than one from a manual tb.
Acting my age is no fun.....
Old 05-25-2004, 02:38 PM
209 neon's Avatar
209 neon 209 neon is offline
no difference just the auto
STOCK MOTOR 14.5 with minor bolt-ons:
ICEMAN COLD AIR INTAKE
HEDDMAN HEADERS
CATCO HI FLOW CAT W/STOCK 2.25 PIPING
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
ENERGY SUSPENSION MOTOR MOUNT INSERTS
NO POWER STEERING UNIT/ NO A/C UNIT
"RACE ME IF YOU WILL BUT REMEMBER IN THE END ITS STILL JUST A NEON"
Old 05-26-2004, 11:48 AM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
nothing, different, only the auto, but i heard you can get a jeep 4.0 liter tb and itll work.........i heard
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
Old 06-06-2004, 08:10 PM
Pedros91 Pedros91 is offline
Send a message via AIM to Pedros91
Question Re: Re: DOHC Throttle Body vs SOHC Throttle Body
what year jeep is this from????
Old 06-11-2004, 03:40 PM
98JADENEON's Avatar
98JADENEON 98JADENEON is offline
if you use the jeep t/b you have to open up the intake. the t/b is 60mm so the stock opening is to small. best thing to do is go to a junk yard get an auto t/b and take it to a local machine shop and tell them to bore it to 56mm that will work without having to enlarge your intake and it will make a ton of diff.
Flowmaster, Iceman, 55mm AF/X TB, Front and Rear BOMZ Racing Strut Tower Bars, Prothane MM inserts and Total Bushing Kit. Carbon Fiber RX300 Tails, .
http://www.slateracing.com
http://www.dmvrscca.org
Old 06-11-2004, 03:44 PM
If you go too big with the throttle body and intake, it will kill your low end power unless you have something behind it pushing the air in. ie turbo, ram air......
Old 06-11-2004, 03:48 PM
98JADENEON's Avatar
100% true that is why i have just a 55mm AF/X works great and i did not loose any low end and i gained tons of throttle responce and mid-range and top end were you need the power the most
Old 06-14-2004, 08:34 PM
I know all that but what year jeep can I get that Tb off of
Old 06-15-2004, 12:34 PM
i think its off of the 93 or so model wrangler, and its not going to kill you power that much at the bottom, do a little research and stop tell everone to get a turbo
