Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 05-25-2004, 08:16 AM
stargaser stargaser is offline
Tapping sound on start up
Hello all
For the past four months or so I have been hearing a tapping sound whenever I start my car in the mornings.It usually goes away after about 7 seconds but I would really like to get it sorted out.
The engine is a RB20DE.
Old 05-25-2004, 11:49 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
RB motors have solid lifters. It sounds pretty normal for engines that would have over 100k kms on it. You can go to a slightly heavier oil such as a 10w-30 or even 10w-40.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 05-25-2004, 01:25 PM
Re: Tapping sound on start up
Thanks for responding
The engine has 222,443 km on it as we speak so I will try the grade oil that you recommend and see what happens.
Thanks again.
Old 05-25-2004, 04:23 PM
my3rdskyline's Avatar
my3rdskyline my3rdskyline is offline
Send a message via AIM to my3rdskyline
Re: Re: Tapping sound on start up
Thanks again.
da da da da daaaaaaaamn
Old 05-26-2004, 06:17 AM
Re: Re: Re: Tapping sound on start up
The RB engines are the greatest man, with the exception of the tapping noise on start up she still runs very very well,no topping up of oil between oil change or anything like that.
Old 05-26-2004, 07:19 AM
I hope my poor RB lasts that long, but if she doesn't I got another one under a tarp in my back yard :-)
Old 05-26-2004, 11:23 AM
RazorGTR's Avatar
Skyline Man
A very good mate of mine has an R32 GTS-t (RB20DET) with 230,000+ kms (143,000 mi) and it still runs good. Burns very little oil and is still making around 300hp. He's went through 3 auto gearboxes and recently had it converted to manual.
I've got just over 136,000 km's on my GTR and only the turbo seals are giving me grief, but since they are factory turbos that is to be expected.
Old 05-27-2004, 01:06 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
there is also an additive that you can add to the oil to get rid of the noise. (cant remember the name though) worked a treat on my noisy old GTE
Old 05-27-2004, 04:48 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Morays Upper Cylinder Lubricant!
Works wonders on older well worn engines.
But you might find some heavier oil is all thats needed. I would throw a bottle of nice pure mineral 20-50 penzoil in there :-)
Remember the RB is an old enigne desgin, from a manufactor that knows how to build enignes.
Old 05-27-2004, 06:16 AM
Thumbs up Re: Re: Tapping sound on start up
I am going to try and see if I can get the Morays stuff thet you mentioned here in Jamaica where I live.If I can`t find it out here I might have to try the U.S.A.
I will also give the Penzoil a shot, that should be much easier to get.
Old 05-28-2004, 12:06 AM
Moppie's Avatar
Master Connector
Well any 20-50 will do, I just happen like the Penzoil after useing it in my previous cars, one was a 2.5l 6cyl with more than a little work done to it.
It also has the advantage of comeing in a 5l container, most of the oil we here in NZ is in 4l containers, which is only enough for the average 4cyl.
Old 06-02-2004, 07:24 AM
I am going to get some 20-50 pop one in and see what happens.
If I was going to keep the car then the noise woud be O.K. but nobody wants to here a noise when they come to purchase a car.
Old 06-02-2004, 11:44 AM
RazorGTR's Avatar
Skyline Man
I hope you DON'T!
Moppie please don't give out advice like that unless you KNOW what you are talking about. RB motors are natorious for pumping great volumes of oil to the head and draining slowly!
You can starve the sump if you do under high revs and blow your main bearings.
Old 06-03-2004, 06:02 AM
I hope you DON'T!
I have not change the oil as yet.I really don`t need to blow a bearing as as I mentioned before I am going to sell the car and I really don`t want to be spending too much money.
I am going to try the slightly heavier oil that you suggested in your first post and move up gradually if it is required.
Old 06-09-2004, 04:33 AM
Moppie's Avatar
Master Connector
I find it hard to believe the drain holes in the head are so small they are unable to drain a 20w oil at operating temprature, it would imply a rather serious design flaw.
Its not uncommon for many engine designs to hold excess oil in the head after being run at high RPM, but you would have to pump out well over 3L from the sump before any damage would be to done to bearings, and long before that happened the low oil pressure warning light would have come on (and hopefully put the engine in limp mode, assuming it has one).
