Old 05-25-2004, 03:24 AM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Hmm...Very bad I suspect ?
Hey guys , I have recently been having a problem with my camaro .
1992 RS 25th - Auto - 50 Z 16's , Lots of engine mods.
Anywho , the problem is from dead stops and mashing my gas while driving at high speeds. I don't know if it has to due with the engine difference or if it's all in the rear end but heres the problem...
When I take off from a dead stop by stomping my gas to kill me some mustangs , A loud bashing ? kind of noise comes from my rear end. It feels as if the rear end picks up a bit on the shocks or something then goes back down. I burn out either way but always and ONLY when I stomp my gas. Sounds like some one smacks my axle with a 20lb. sledge hammer , I have new U-joints , yadda yadda yadda , and it hasn't caused any noticable damage However , It sounds like crap and drives me crazy !
Anyone else had this problem with their camao ?
Thanks
Old 05-25-2004, 03:33 AM
92rs25th's Avatar
Re: Hmm...Very bad I suspect ?
PS - I had the 305 removed and a 350 4 bolt put in.
Old 05-25-2004, 03:41 AM
92rs25th's Avatar
http://www.geocities.com/shotos_chaos/21_3.jpg
http://www.geocities.com/shotos_chaos/32_3.jpg
http://www.geocities.com/shotos_chaos/9e_3.jpg
http://www.geocities.com/shotos_chaos/6d_3.jpg
http://www.geocities.com/shotos_chaos/20_3.jpg
Heres the pictures of the car when I had bought it , pretty much boring and plain cept' the custom paint and cowl hood...Boy , has she ever improved since then =D More pics soon ! dumb digi cam is broken..all money going in to car >.< overstock.com !!!!
Heh , anywho , hope to have spare money for a new cam so you guys can see the total make over of the boring RS XD.
Old 05-25-2004, 11:12 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
beleive it or not, this is a pretty common problem with camaro's. there were atleast 2 people a few months back with the same problem, and i've had it too. i've found that low gear ratio's in the rear end (2:73's etc.) cause this. i dont know if it's a problem with the pinion angle changing under hard acceleration or the cheezy stock controll arms flexing. With a gear ratio like 2:73, your applying alot of torque through a through the driveshaft to a pinion that doesn't want to turn a ring gear with that few teeth. something is going to rotate, being either the wheels or the whole rear end.
oh ya, i also had this problem after changing the engine from a 305 to a 350
Old 05-25-2004, 12:33 PM
Deadcarny Deadcarny is offline
check your Torque arm and make sure it is tight. if your pinion seal leaks the oil will get on the bolts and cause them to easily come loose (some of them are installed with the Bolt through the top and the Nut on the bottom, where this happens).
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 05-25-2004, 03:24 PM
92rs25th's Avatar
I'll due as suggested guys and check it out. Maybe give everything a turn or two to make sure it's all tight. But if I don't find anything to be lose , I think I will throw some serious heavy duty shocks in the back to keep it stiff in the ass for massive accel.
THanks for prompt replies guys =)
Old 05-25-2004, 03:35 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
one more thing to check, i had the same situation a while back. i had broken the rear transmission mount. but it didn't look broken so i delt with the problem for a while. later i put a jack on the tail end of the tranny and jacked it up a little, and sure enough half of the mount stayed on the crossmember and half on the tranny. bought myself some polyurethane mounts and everything is fine and dandy.
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 05-25-2004, 09:18 PM
kmdracer kmdracer is offline
Send a message via Yahoo to kmdracer
Trans mount! I bought my 91RS from a guy who had this problem (and told me about it!) He said a shop had told him that the whole rearend/ bushings needed replacing. $1200 for the car, $20 for the trans mount, and I have a great daily driver. Do like storm said, and put a jack on the rear of your trans ( tailhousing) Lift about 2" and youll prob notice the mount separating.
KevinD
03 ram quad,4.7, a5, patriot blue, stock
99 Z28 5.7ls1, a4, black, Harwood 3" Cowl hood,FRA,GMMG cat-back 283rwhp/297rwtq b4 cat-back
91 RS camaro, 5.0, a4, teal blue, stock ( race project, no stock times yet)
76 c-10 stepside, 355/350, orange and rust, beater truck
My Cardomain site: http://www.cardomain.com/ride/651308
Old 05-25-2004, 10:00 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
92rs25th: Sounds like some one smacks my axle with a 20lb. sledge hammer
sounds like the work of ridge_runner
Old 05-25-2004, 10:03 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
hey hey
Old 05-25-2004, 10:04 PM
20lb is overkill, mine is only like 8
Old 05-25-2004, 10:06 PM
Genopsyde's Avatar
The President
lol, I had to take advantage of that one
Old 05-25-2004, 10:08 PM
haha yea i kno, i figured you would catch that
Old 05-25-2004, 10:12 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
my moms 92 RS makes the same noise...always thought it was something in the trunk that sli back when u hit the gas
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-25-2004, 11:34 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
mine done that, my ring gear had two teeth
broke off.
