Old 05-25-2004, 02:49 AM
spawnripken spawnripken is offline
Question Fuel Injection high Idling problem?
Have an 80's Camaro with fuel injection. The car will not idle under 2000 RPM. Have changed almost everything. Including the injectors. Only difference is when I take the Mass Air Flow sensor connector off it idles down but doesn't run correctly. It has also been changed. The other difference is when I retard the timing a lot then it will idle down but has zero power. When timed correctly it idles way too high. Again most of the parts have been changed. Any suggestions?
Old 05-25-2004, 11:21 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
ok, put the timing back where it's supposed to be or atleast close. you'll need about 4 inches of wire or a paper clip.
pull off the service port panel below the steering wheel and connect the top right 2 pins on the service port with the wire.. turn the ignition on but dont start the car, wait atleast 45 seconds then disconnect the IAC connector, then disconnect the timing advance wire by the passenger side fender then remove the wire or paper clip. start the car and let it run 2 or 3 minutes until it's warmed up and running in closed loop, you may have to give it gas to keep it running. once it's warmed up set your idle speed with the screw on the throttle body untill it's running 5-600 RPM then shut it off, re-connect the IAC and timing advance.
Old 05-25-2004, 09:34 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Fuel Injection high Idling problem?
damn, sounds like youve done this a few times
Old 05-25-2004, 09:48 PM
sykotic1 sykotic1 is offline
hah that was ownage
Old 05-26-2004, 10:54 AM
4onFloor's Avatar
ya i've done it a few times. i'll get retards that dont know what there doing and fuck around with the idle on there car, then they come rolling in my driveway at 2000RPM wanting me to fix it. and oh do i charge them
Old 05-26-2004, 11:47 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
I'd run it for codes first. Could be a bad TPS.
