Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-24-2004, 08:45 PM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
marauder conversion
does anyone know if a marauder conversion kit is avaliable for crown vics? did a search on google but nothing turned up. crown vics and marauders appear to have the exact same dimensions, so basically, i could just swap the bumpers, rims, and headlights....??? any insight?
Old 05-25-2004, 12:46 AM
ModMech's Avatar
ModMech ModMech is offline
Re: marauder conversion
There is no "conversion" kit.
The MM uses a 32V (DOHC) engine, while the CV and GMs use a 16V engine (SOHC).
You can take the nose, and rear facia from a MM and graft it onto a '03/'04 CV or GM, but that won't make it a Marauder.
Old 05-25-2004, 01:51 PM
ok, thanks alot for the info. yea, i knew that the engines were not the same. i was just curious if it was possible. but anything is possible with enough money...
Old 06-09-2004, 09:13 AM
landyacht's Avatar
landyacht landyacht is offline
You're better off just buying the Marauder then doing a conversion. It'll save you money doing it that way! Plus, you don't have to wait as long for the car to be ready for you!!
If you've looking to do the conversion because you want to have a sleeper car, just buy the Marauder and paint it and change the rims/tires. It'll still be cheaper.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 10-11-2005, 10:09 PM
Shick1988 Shick1988 is offline
Can you maybe put the head and tail lights on to a 2000 cvpi, or is there that big of a difference?
