Old 05-24-2004, 09:43 PM
Hybrid1990crx's Avatar
Replacing head gasket...what all should I get?
I plan to replace my headgasket on my hatch this weekend and I'm wondering what all I should get. Someone told me to get a headgasket kit or something. So does that include the head gasket and intake and exhaust mani gaskets? Or is that pointless and should I just get a headgasket? I know I should get one for a z6 or y8, because its metal and wont blow out, and it also raises compression a bit? And I need new head studs, right?
Also, the car only overheated once for like 10 mins, so what are the odds of my head to be warped? It still runs fine besides for the getting hot thing, so I haven't driven it at all since.
Old 05-24-2004, 10:06 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Replacing head gasket...what all should I get?
Head gasket set. Comes with every thing you need. Head gasket, intake/exhaust gaskets, valve cover gasket thermostat housing gasket ect. All head gaskets are metal. All head gaskets can blow out. Shorter head gasket will raise compression but not enough to see any differnance. Odds of it being warped are slim. The head bolts can be reused, just not more than three times, other wise you risk failure.
Old 05-24-2004, 10:07 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
well it depends how you want to do it...
what you NEED
head gasket, gasket sealer, antifreeze and oil.
what you should also get
intake manifold gaskets, exaust manifold gaskets, valvecover gaskets & head bolts.
kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 05-24-2004, 10:12 PM
Forunn Daberator
dont use gasket sealer on head gaskets
Old 05-24-2004, 10:20 PM
mjgjr72 mjgjr72 is offline
headgasket set, may want to have the head checked just to be sure inless you don't mind doing it again better safe than sorry
mybe some plugs, wires cap, rotor, t-belt, waterpump, and t-stat while your at it.
Old 05-24-2004, 10:30 PM
Forunn Daberator
Re: Re: Replacing head gasket...what all should I get?
Yeah he has a good point, I would definatly recomend putting on a new timing belt sence you got to pull it anyway.
Old 05-24-2004, 10:41 PM
well technicaly you don,t most hondas have a small rubber grommit on the cover and you can loosen the tensioner bolt and pull up on the belt and retighten the bolt to hold it.
but a head job is pretty involved might as well do some maintainace while your at it
Old 05-25-2004, 10:22 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
He probly ment to get copper head gasket sealer, its good stuff. Also you will need something to clean where the head and block seal together. I used tons of razorblades to scrape it clean but there are alternatives.
DOHC ZC 89 DX HATCH
Old 05-25-2004, 03:56 PM
well should I get a head gasket for a a6 or a z6? I was told the z6 is much better. Anyone else know about that?
