Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-19-2002, 12:35 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
zc+turbo?
how much horsepower would the zc with with the greddy turbo running about 9psi w/ intercooler and lowered compression to 8.5 i think is what the pistons said still shopping aorund just curious
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 01-19-2002, 03:10 PM
turbocivic4 turbocivic4 is offline
9 psi
9 psi u will have to do some things to ur motor man block guard fuel pump rising rate fuel reg, fuel management and tuning!!
1993 Honda Civic Dx
Auto to Standard Conversion
D16Z6 conversion 1.6 Sohc Vtec
Gude Turbo Head w/ Cam
Greddy turbo charger w/ Intercooler
Blitz Electronic Boost Controller
Weopon R Fuel Regulator
MSD Ignition w/ Coil
Bullfrog Throttle Body
Aem Underdrive Pulleys Nology Wires
AGX Suspension
Exhaust Systems
All Strut Braces
15 inch Albas w/GoodrichEuro Tires
Sparco Torino Seats
Carbon Fiber Dash
Momo Steering Wheel
Shift knobs w/ pedals
APC White Guage Faces
Custom Black Carpet
Old 01-20-2002, 10:35 AM
pvang31019 pvang31019 is offline
Re: 9 psi
hahahaha......funny
Old 01-20-2002, 05:23 PM
spy54's Avatar
:huh: :huh: :huh: you mean to tell me i would have to do block work to run 9 psi?
many people run more than that on stock internals 9 is about as high as i would go i would probly run it at like 5 generally
AF Teen Crew
Old 01-20-2002, 07:35 PM
91zc 91zc is offline
You can probably run 9 psi on stock internals if you are running an intercooler and have a good fuel setup. I don't know if the boost dependent fuel regulator will cut it at 9 psi. At this much boost on stock internals tuning is critical. As a matter of fact tuning is critical at any boost level if you want the motor to last and be reliable. I have heard that d series rods tend to go out when the hp approaches 215 crank hp.
91 civic 4dr
b16a
14.8@94
Old 01-21-2002, 01:08 AM
yeah
Yes Pvang we all no where the intelligence came from!!!!!!
Couple forums bak that is!
1993 Honda Civic Dx
AGX Suspension
Exhaust Systems
All Strut Braces
Sparco Torino Seats
Carbon Fiber Dash
Momo Steering Wheel
Custom Black Carpet
Old 01-21-2002, 12:12 PM
Re: yeah
at least I can figure out what's wrong with my motor on my own
Old 01-22-2002, 07:37 AM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
You could skip the boost dependent regulator if you went with a programable ECU such as the Zdyne unit and bigger injectors. The Zdyne would be helpfull getting the ZC to run at it's potential and very helpfull with the ZC+turbo although the unit is not cheap at almost 1,000 bucks.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 01-22-2002, 07:09 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
To dispell the rumors, with your compression lowered to 8.5:1, intercooling, and only 9 pounds of boost, you don't need block work, and minimal safeguarding is a good idea, but I don't think you will need it until you go for 10+ psi of boost. As for horsepower, hard to say.
