Old 05-24-2004, 07:40 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Adire vs. Elemental Designs
See my amp here
Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm)
Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 12-3/4"
Which Sub?
Adire Shiva here
Elemental Designs 13.kv.2 here
Old 05-24-2004, 09:30 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Adire vs. Elemental Designs
all opinion IMO
www.cloudcity.deviantart.com
Old 05-24-2004, 10:15 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Since the Kv2 isn't out yet, it will be hard to find opinions or comparisons on it
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-25-2004, 12:42 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
The Kv2 won't ship until mid june so if you want something now get a shiva...theres some on ebay brand new for 125 shipped...I figure they would be fairly comparable other then the fact that a shiva is gunna be better in a larger snclosure while the kv2 in a smaller one.
Old 05-26-2004, 07:29 AM
so with my amp, would I want to order dual -4 ohm or dual -2 ohm?
and then whichever one I get, how should I wire it to the amp?
Old 05-26-2004, 08:36 AM
JC80 JC80 is offline
Get the dual 4 and wire it series/parallel...I doubt that amp is 1 ohm stable so there is no point in getting the dual 2.. Have you ever seen that amp push? I have one and took it out replacing it with a JBL 1200.1, after I had it hooked up I took it straight out blowing both 25A fuses on the amp b/c I didn't even take the time to unhook the + from the battery..for about $90 more for the JBL it was well worth it..but thats MO
Old 05-26-2004, 01:10 PM
How exactly does the cone on the ED sub work? It isn't even really a cone, because it has a flat front to it....ive never seen that before
Old 05-26-2004, 03:08 PM
Haibane's Avatar
Those are still called cones, convex, concave, are the ones you are used to, cone is just the name for that part of the sub. It works like any other sub, just amazing bass reproduction.
Old 05-27-2004, 07:55 AM
So I was looking at the ED site, and (in the eK12) they have either a single 4-ohm voice coil, or dual-4 ohm voice coils. When i looked at their wiring diagrams, is looked like that with th DVC one, i could only get either 2 ohms in parallel, or 8 ohms in series. would it be better to get a DVC and run it at 2 ohms? or a single 4-ohm and run the system at 4 ohms (amp specs top of page)
Old 05-27-2004, 08:21 PM
sr20de4evr's Avatar
If you only got one sub, then you would want the single 4ohm so you could bridge the amp to it
'01 Black Sentra SE
'05 Silver WRX STi
