Old 05-24-2004, 06:22 PM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
ECU and Harness Question. Project Civic 101
Replaceing the VTec 1.6 sohc with a 2000 b16a2 both 5 speeds.... I have the ecu for both wheres a good place to check on the harness variables....Or if anyone has done this swap and knows the changes ....Please advise.....
Follow the link to see.....Leave me some feedback please.
Progress Civic 101
Thank you
E. Honda
Old 05-24-2004, 06:43 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: ECU and Harness Question. Project Civic 101
so you have a 5th gen, all you need is an OBD1 to OBD2 conversion harness, and everything will plug right in.
Empty Pockets Racing Member #1
Old 05-24-2004, 07:36 PM
jameskersten jameskersten is offline
Re: Re: ECU and Harness Question. Project Civic 101
still need to wire a few things into the harness dont you? knock sensor,extra o2 sensor,etc. correct me if i am wrong. i have done a few obd1 to obd1 swaps but not obd2 to obd1
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
Old 05-24-2004, 08:07 PM
E Honda's Avatar
The b16a2 was already in a 95 civic the check engine light was on and the seller claims it was a tps code I agreed to give back the wiring harness that was in the car in hopes of making mine work. There were 3 wires changed on the harness. Taking a break to get my mind right and will post follow up. Also while swapping I took the 134 AC parts and swapped from the r12. Keeping the link updated with what seems hourly progress...lol
2nd oxygen sensor?.........I have only 1 outlet on the header.....Where would the 2nd be?.....And since I have no provision for it suggestions????Updated pics!!!!!
Yours truly
E.Honda......
Old 05-24-2004, 09:00 PM
if its an obd2 motor the secondary sensor would be further down the exhaust system. i believe on a 2000 si it would be on the cat. if its a obd1 motor there will only be the one.
Old 05-24-2004, 09:28 PM
E Honda's Avatar
the motor was in a 2000 civic si Only had 1 oxy sensor when removed from the 95 civic organ donor.
Considering wiring up with the 93 harness, everything plugged in. Alt plug is different. Check for codes....If no codes bonus.....If codes present then address those wires in the harness pending no bsd sensors.....Suggestion
E. Honda Esq.
