Old 05-24-2004, 03:03 PM
makaveli3004 makaveli3004 is offline
Amp Shuts off then turns on
Hey recently i will turn the volume up on my deck and after a short time of a alot of bass the amp will shut off. after about 5 minutes it will come back on. i jus installed a power cap and replaced the fuse what could be goin wrong
http://members.cardomain.com/makaveli3004 My 97 Camry
Old 05-24-2004, 05:06 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: Amp Shuts off then turns on
possible overheating; where is the amp mounted?
Old 05-24-2004, 05:40 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yep, sounds like your amp is thermal cycling (overheating) ....... it could be you have too low of an impedance load and/or playing it too loud too often
Old 05-24-2004, 05:46 PM
AZFlyingDiver AZFlyingDiver is offline
so...
(1) turn the gain down goin to the subs and see if your "play time" will last a little longer
(2) check to see your cap isn't oversized - you don't need 1000 if you can benefit from a 500
(3) consider rewiring to 4 ohms if you're wired at 2 right now
just some thoughts...
Old 05-26-2004, 02:32 PM
ok i tryed turning down the gain and then it barely hits at all. maybe its the power cap??. i have this amp http://www.bestbuy.com/site/olspage....7&type=product wired to a 1.5 fahred cap.
Old 05-26-2004, 02:34 PM
just turn down the gain a little bit, not a lot, to see if that helps. i still think its a heat problem, where is the amp mounted?
Old 05-26-2004, 02:44 PM
its attached to the back of the box right behind the seats
you can see pictures here http://members.cardomain.com/makaveli3004
Old 05-27-2004, 06:48 AM
A lot of people discourage mouting the amp to the sub box for the reason that when the subs hit, the box vibrates, and heavy and prolonged vibration is not good for an amp with sensitive insides. I would get your amp checked out to make sure it is working fine, then I would mount it elsewhere
Old 05-27-2004, 03:11 PM
cliffb4n8r cliffb4n8r is offline
What impedance are you running those at? Because if those are both 4 ohm subs and you've got 'em wired in parallel mono(the way you would naturally wire them if you didn't know better) You'd be at 2 ohms and therefore lucky your amp isn't broken altogether
Oh, and I don't subscribe to the whole vibration theory. because if your amp is anywhere near your subs it will get a lot of vibration, and any good amp(not pyramid or road gear or jensen...) should be a ble to handle it...
Old 05-27-2004, 08:18 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Amp Shuts off then turns on
The amp vibrates more from being mounted on the chassis of the car (gravel, bumps, etc) than from being mounted on the sub box. There are a couple downsides to mounting on a box though. Like if you take off your amp you now have holes in your box, or if someone breaks in it makes it nice and easy to steal your whole setup at once.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
