Old 05-24-2004, 11:31 AM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
bigger better?
The bigger you box (ported) the better? Can it be too big?
Old 05-24-2004, 03:46 PM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
Re: bigger better?
no, every speaker has specific values, you need to calcualte these sort of things, of it will sound like crap.
Old 05-24-2004, 05:43 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
especially for a ported box ...... the box and port size have to be pretty carefully matched to the speaker
Old 05-25-2004, 09:09 AM
Heres what brought up the question. If a box was TOO big, then would'nt it perform as if it were in free-air? Say I get a 12, and I have 30 cubic feet in my trunk, and i make the box 28 cubic foot sealed, wouldnt it sound like free air? Someone should get the idea at what I'm trying to say.
Coming soon..RE XXX 18'', Hifonics Brutus Amp..Any comments on these products please respond in any thread of mine.
Old 05-25-2004, 12:40 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: bigger better?
No....you still ahve a seperation of the waves unlike in free air. Usually a bigger box will play lower and louder, but only up to a point. If ou tried to put say an e12o in a 5 cube box it wouldn't work out right b/c they are made for smaller boxes....generally in spl apps the designer of the box will make it in the upper reigion of the ported box volumes.
Old 05-25-2004, 06:11 PM
Audio Guy
actually, yes ...... free air always has a baffle between the front and rear of the speaker - in the home, it's known as infinite baffle. Yea, I know, the term "free air" is not a very good one ... you usually see it used to describe woofers designed to play into a door, trunk or hatch.
Old 05-26-2004, 09:11 AM
Re: bigger better?
I still dont understand, one says yes, one says no. To me it would almost seem like it was free air, 28 cubic foot is a BIG box. and thats WAY to much air space for a 12, any 12? I dont know that. But as far as it sounding free air, this is a good question.
Old 05-26-2004, 09:17 AM
JC80 JC80 is offline
Re: bigger better?
If your going to run free air than run free air..its a total space saver and the only reason for it...not meant to be backed by a 68 cu.ft. box or whatever, you take away from the point..Theres exactly the same reasons why you make a box to specifics..same as making a box too small, you can make it too big.
There isn't a point to making a box that big unless you have a 34" Audiobahn Linear Compression Subwoofer in it.
Old 05-26-2004, 03:16 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: bigger better?
and if you have a 34" audiobahn subwoofer, you got screwed out of some money that would have been better used at getting 2 18"s to do more power and more excursion cleaner lol.
www.cloudcity.deviantart.com
Old 05-26-2004, 05:41 PM
Audio Guy
Re: Re: bigger better?
you obviously have some preconceived notions ..... just empty all of what you think you know about this from your head. As stated in my last post, another name for free air (in car audio) is infinite baffle (in home stereo). The speaker has an incredibly stiff suspension, and so it doesn't require the back pressure restoring force of a small box. Playing a speaker in "free air" does NOT mean you just hang it by a wire ...... the back is still seperated from the front by a baffle, like a door panel or rear shelf. Like I said earlier, the term free air is a poor one.
Old 05-26-2004, 09:35 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Re: bigger better?
Another definition of a freeair enclosure is one where the box size is 3x larger than the Vas of the speaker. If it was ported and this large, it would most likely act like an IB sub with a hole in the baffle, I doubt the normal rules applying to ported boxes would hold true.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-26-2004, 09:46 PM
Haibane's Avatar
Re: bigger better?
wow... a ported IB, that would be weird...
