Old 05-24-2004, 08:06 AM
Racerx328 Racerx328 is offline
96 Cherokee water pump
I have a 96 Jeep Cherokee and twice now i've had to replace the water pump because the water pump blades litterally erroded and it ended up looking like a blender blade. The first sign I saw was the coolant turned a dark rust color and then a couple of months later the jeep would start to over heat. Does anyone know how or why this would happen?
Old 05-24-2004, 12:41 PM
Dale Aeppli Dale Aeppli is offline
Re: 96 Cherokee water pump
HI, SOUNDS LIKE THE PUMPS ARE DEFECTIVE DO YOU USE A LUBRICANT WHEN REPLACING THE PUMPS. YOU SHOULDUSE ONE ALSO MIX YOUR ANTI FREEZE 1/2 GAL. ANTI-FREEZE TO A 1/2 GAL. DISTILLED WATER DISTILLED WATER CUTS THE CALICUM BUILD UP. I USE DISTILLED WATER BOTH FOR BATTERIES & RADIATORS. QUESTIONS GIVE A HOLLER PUMPS SHOULD BE UNDER WARRANTY DALE
jeepman600@aol/com
