Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-24-2004, 12:51 AM
DropdHatch's Avatar
DropdHatch DropdHatch is offline
Send a message via AIM to DropdHatch
Exhaust system question.
I wanted to get full cat back on my 1988 civic hatch but I dont want the exhaust to come out on the right side where the slit in the bumber isnt cut. Is there a way you can run the exhaust pipes along the left of the car so it comes out on the correct side? Also where can I find catback but not including the muffler, just the pipes in between.
Live life by the gear... My cars slow so I've been in 1st for a while.
Old 05-24-2004, 02:20 AM
Al_Bundy's Avatar
Al_Bundy Al_Bundy is offline
Re: Exhaust system question.
DNX has some mid pipes. mandrel bent 2 3/8" tubing and stainless steel. WLK-38212 88-91 civic si 1.6l $116.88 from summitracing.com
Old 05-24-2004, 05:43 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
You want either a custom made exhaust or a system like Tanabe or Thermal.
Tanabe is like a "coffe can" muffler which exit's the car on the left side and the Thermal system has a setup like stock but performance is not sacraficed the muffler sit's sideways under the car and a pipe with a tip on it then exit's the car on the left side.
www.nopi.com has some picture's of each im sure go there and see what you like.
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-24-2004, 12:51 PM
DropdHatch's Avatar
So there is room on the left side of the car where I can run an exhaust and not have a problem?
Old 05-24-2004, 07:36 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
nope i tried running a pipe straight down the left side, but without using a plasma cutter, and moving some things, its impossible for it to go that way.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-24-2004, 09:10 PM
DropdHatch's Avatar
What does a plasma cutter have to do with anything?
Old 05-25-2004, 02:36 PM
crxlvr's Avatar
becuase part of the frame is in the way on the left side, so unless you cut that piece off, you wont be running the exhuast down the left side of the car.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-25-2004, 02:56 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
would a setaline (sp) torch work? my shops got one....having a strait exuast system w/ the ability to use whatever muffler i want woudl be nice
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 05-25-2004, 07:20 PM
DropdHatch's Avatar
Can you gimme a direct link to them pipes on the nopi page cuz i dont see any for that cheap.
Old 05-25-2004, 09:14 PM
crxlvr's Avatar
not to sure, i dont really know much about it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-26-2004, 06:54 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
by saying running it down the left side you mean going through the same way along the left side by the rear wheels? i was thinking about doing it exact same as right side, only on the left so there's no big long piece of pipe sticking across the back of the car... thoughts?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-26-2004, 07:39 PM
crxlvr's Avatar
yea thats what i was saying, i wanted to run the pipes down the left side of the car and straight out the back, instead of doing all the bends for the right side, but there isnt enough room.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-26-2004, 10:01 PM
DeleriousZ's Avatar
on your civic tho right... i wonder if my teg is any different.. if not, what type of slicing and dicing would you have to do?
Old 05-27-2004, 08:08 AM
crxlvr's Avatar
well part of the frame, and the rear suspension along with a few brake line needed to be moved, wasnt worth it in my eyes, so i just ran it straight back on the right side, i dont care if there isnt a notch for the exhuast.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
