Old 05-23-2004, 11:08 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
boost gauge problems
I hooked up my boost gauge and it when i turned the ignition key over it went to zero all right good started it went to correct boost...shut off my car tried it again and when i turned the key over it went to 2.0 and when i turned it back off the needle bounced but then went back to 2.0...what happened!?
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 05-24-2004, 12:55 AM
gelman4u gelman4u is offline
Send a message via AIM to gelman4u
Re: boost gauge problems
i would say check all your connections, i had the same problem, but my vacuum line just fell off. If that doesn't work then post again.
Old 05-24-2004, 08:44 AM
Nstyle29's Avatar
well i checked the fuses and they were blown, so i replaced them but no fix on the gauge!
Old 05-24-2004, 10:30 AM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
I have a similiar problem with my boost gauge, sometimes ,well most of the time, when i start my car the gauge reads 0 but when i start building boost it reads it just fine but it dosnt drop to show VAC, but a few mins later it will drop to the correct VAC and work fine. Any ideas of what could be wrong.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-24-2004, 12:19 PM
Nstyle29's Avatar
my problem is that when i turn on my car it reads past 2.0! i haven't taken it out for a spin yet to see if it will read boost or not, i might try and do that once i get everything put back together...please need help, is the gauge broke!?
Old 05-24-2004, 12:54 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: boost gauge problems
What kind of boost gauge is it? How is hooked up now? Is it a straight boost gauge or a boost/Vacuum gauge? What line did you tap for the gauge?
Old 05-24-2004, 01:18 PM
Nstyle29's Avatar
Its a 52mm electronic greddy boost gauge. I don't know the diff between boost and bst/vac, i tapped the line that it shows on prostreets website.
Old 05-24-2004, 01:27 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
If it is an elec, you could have a voltage issue.
Kris
2012 Genesis Coupe 2.0t
Old 05-24-2004, 02:32 PM
Nstyle29's Avatar
I will tell ya where the wires are going, most of them are going to the lighter...black one to the black wire with silver dots, the orange one to the blue wire, the white one to the green wire with white stripe, and then the red one is going to the red wire off the light that is built into the console to show that there is an alarm...that little red light
Old 05-24-2004, 08:07 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i have that same 'occurance'. i would say it happens less often, but if i give the car a little gas as soon as it gets a good turnover it is eliminated. i have also found no adverse problems with it running like that either. i also have the ProfecII that has a built in boost gauge and it reads the same as the gauge when it does that. it's strange to say the least...
as far as the this thread, make sure you have the correct line tapped for the gauge.
